Author Topic: Now that I've been delving into the world of old keyboards...  (Read 1380 times)
Offline jkercado
  • Green XM clickclacker
« on: Fri, 16 December 2011, 20:38:15 »
I've come to realize that no company had better quality plastics than IBM. After you handle something like an Model M, everything other plastic feels thin, hard and loud. I look at my Model M built in 1993 and the keys are not even faded. I look at my co-worker's Das Keyboard, the one he bought 6 months ago, and I can already see some shiny parts on the spacebar.
Again, IBM manufactured (for the most part) ridiculously solid stuff.
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
« Reply #1 on: Fri, 16 December 2011, 21:33:01 »
Get a Model F and take it apart (the big 122s are much easier). You will see that it is, indeed, the Mac Daddy and that the M was a cheapened downgrade.
The only major downside I see is that the plastic case is more brittle, and this is an even bigger problem on the F AT, because of the way the case snaps together, especially at the front (spacebar) side.
The M probably used a softer, cheaper, plastic case, but its flexibility makes it much more forgiving.
- D Trump 2026-09-28
Offline pitashen
« Reply #2 on: Fri, 16 December 2011, 21:53:00 »
Quote from: jkercado;472555
You can still get the "better quality" plastic keycaps for your modern keyboards. PBT plastic is the keyword. PBT is a harder plastic material that is more resistant to finger polishing.
Offline jkercado
« Reply #3 on: Fri, 16 December 2011, 23:07:06 »
Quote from: fohat.digs;472570
Many years ago I worked as an IBM AS/400 programmer...So I know what you're talking about. :becky:
Offline flaming_june
« Reply #4 on: Sat, 17 December 2011, 00:22:47 »
But just because key caps on plastic shines doesn't mean the board isn't well made though.
« Reply #5 on: Sat, 17 December 2011, 08:09:31 »
Does the Model F have lighter action?
This subject has been debated at length.
I do believe that the Model F has a lighter touch. The actual weight may be similar, but it seems to have a more delicate and precise feel, to me.
