Author Topic: 10keyless MS 4000  (Read 5843 times)
Offline bbbbqq
10keyless MS 4000
« on: Fri, 16 December 2011, 21:46:38 »
Just modded my old MS4000 into a 10keyless board. A good board made excellent. Not a difficult mod, either.
[size=+2]Disassembly[/size]
    [*]Remove every keycap
    [*]Clean your keyboard. Don't let it look like this:
    [*]Unscrew all 21 (!) screws from the bottom
    [*]Unscrew the two screws under the spacebar
    [*]Remove the wrist rests (just pull
    [*]There is one screw under each wrist rest, joining the silver plastic to the bottom. Unscrew.
    [*]The center portion with the leds has a small clip joining the silver plastic to the bottom. Slip a screw driver in, give it a twist to unlatch the clip.
    [*]The top plastic and bottom can now be removed.
    [/LIST]
    [size=+2]Inner workings[/size]
      [*]As expected, the board is very simple inside: 2 sheets of plastic with printed traces, and a few sheets of membranes. Take off the membranes and the sheets. You should now have just the top and bottom plastic. Maybe the controller too, it doesn't matter.
      [*]Mark out where you want to cut. I recommend the left edge of the numpad, since it is smooth plastic there.
      [*]Match the top and bottom cover and the right hand wrist rest, maybe fasten a few screws to hold it together
      [*]Cut where you marked it out. A band saw would work best, but a hand saw will as well.
      [*]de-burr. Deburr the **** out of it.
      [/list]
      [size=+2]Reassembly[/size]
        [*]Put the sheets of plastic back in, and the left hand membranes.
        [*]On the right hand membrane, mark out where the numpad is, and use a pair of sharp scissors to cut only the rubber sheet. Do not cut the plastic sheet.
        [*]Use tape between the plastic sheets where the numpad would have been. You cannot let the two sheets touch where the traces are, or it will register.
        [*]Fold the overhanging part over, and tape it to the bottom of the board.
        [/list]
        Result:
        Disadvantages:
        - Can't use the numpad led anymore
        - The feet of the board will be cut off, and you will need to ghetto some feet. I used cardboard and tape.
        - Cut edge can be a bit sharp
        Idea from http://tlb.org/keyboardchop.html
        Offline SmallFry
        10keyless MS 4000
        « Reply #1 on: Fri, 16 December 2011, 22:01:20 »
        Nice job. Lanx also does stuff like this. His projects are quite insane to say the least.
        Offline flags
        10keyless MS 4000
        « Reply #2 on: Sat, 17 December 2011, 00:25:45 »
        Inspired me to do the same with an old keyboard I had laying around. Looks good!
        KBC Poker w/ Blue Switches - Razer BlackWidow
