Author Topic: How do you get the back off a full sized Filco?  (Read 1785 times)
Offline nhwhaup
« on: Sat, 17 December 2011, 07:43:49 »
I'm looking to take the back off my Filco.  I loosened the two screws on the back and it comes loose but appears to still be clipped in somehow.  Are there additional screws that must be gotten from the front or clips that I need to release?  I don't want to force it and break it.  Any help is appreciated.   Thanks.
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline Ekaros
« Reply #1 on: Sat, 17 December 2011, 08:02:51 »
There is one under the OK-sticker. Then there is clips at front 3 I think. Atleast MJ1 was such.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline nhwhaup
« Reply #2 on: Sat, 17 December 2011, 08:40:28 »
So if I get all 3 screws off will I be able to wiggle it off and get the clips free?
Offline nhwhaup
« Reply #3 on: Sat, 17 December 2011, 09:19:55 »
I am able to loosen up the back pretty good by taking out the screws.  But the back is still held on tight at the bottom of the board.  How do I release the clips?
Offline nhwhaup
« Reply #4 on: Sat, 17 December 2011, 10:15:50 »
nevermind - I was able to get the back off - had to use a butter knife to find and loosen up the clips.
Offline nhwhaup
« Reply #5 on: Sat, 17 December 2011, 11:56:21 »
Quote from: ripster;472750
Butter knife is the best tool.  You butter believe it.
Hehe - of course it's the Ripster humor....
Offline Ekaros
« Reply #6 on: Sat, 17 December 2011, 12:25:25 »
Quote from: ripster;472804
Answer was in my sig btw: F3 "Opening Up Filco".
Maybe I should change it from 95% to 99%?
So do you have Filco's matrix/pin-layout anywhere?
[SIGPIC][/SIGPIC]
