Author Topic: Choc Mini & Numpad together  (Read 2600 times)
Offline Nadger
« on: Tue, 20 December 2011, 18:22:09 »
I own a Noppoo Choc Mini, which has an integrated numpad laptop style across the right side of the 890uio etc.  Its not very functional to use so I want to get a separate numpad for those times when i need to do a long number entry.  However im not sure if there is a specific type of numpad out there i need to get that always works even if numlock is off.  If numlock is on, i cant type/use right half of keyboard due to the mini nature of the board...So is this just something i should solve with AHK or is there a hardware solution out there as well?
● Logitech ♦ G600
● Noppoo ♦ Choc Mini 茶轴
● Plum ♦ 96 White / Red Switch
● Microsoft ♦ Xbox 360 Windows Controller
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Tue, 20 December 2011, 19:50:35 »
There are numpads that send make/break numlock with every keypress.  These would be compatible with the noppoo.  This thread has my AHK script for numpads that don't do that.
Buried in some wiki somewhere is probably a list of numpads that do the numlock dance.  Here is a previous thread with some links.  Here is the Kinesis version (that I thnk is also branded as Addesso elsewhere) that I have heard does the numlock deal.
Filco w/ Imsto thick PBT
Offline Human
« Reply #2 on: Wed, 21 December 2011, 01:37:36 »
Here you are
http://keyboardporn.com/mx-switch/goldtouch-keypad/
P.S: May got blocked if your network is being parental control ON...
Offline alaricljs
« Reply #3 on: Wed, 21 December 2011, 01:42:46 »
Yeah, that's the one Kinesis rebadges.... probably a few other names to be found on it as well.
