Author Topic: Help finding a keyboard carrying case?  (Read 5966 times)
Offline NguyenAdam
« on: Thu, 22 December 2011, 01:51:52 »
I posted this on OCN, but I wanted to see what you guys could find here. Are there any keyboard carrying cases similar to the Leopold one on EK?
http://elitekeyboards.com/products.php?sub=access,cases&pid=leo_tkb001
I'm gonna need one for LANing, but the problem is that I don't have a tenkeyless board. It would be great if someone could find me of something similar, and cheaper is possible. Thanks
Offline HeavyArms
  • "Lit"
« Reply #1 on: Thu, 22 December 2011, 03:05:46 »
There are a couple threads on this, just search carrying case and you will find a few. I went to this year's MLG Raleigh and STBomber had a sick sling backpack that was dedicated to a keyboard and mouse, as well as a few other peripherals. I've been searching for it for a while, but no luck. The Keyboard Quiver is an ok solution, but I dont know if they are still available.
Head in the clouds.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Thu, 22 December 2011, 11:55:01 »
best and only solution out there right now for fullsize keyboards is probably the Razer Keyboard Bag
Offline NguyenAdam
« Reply #3 on: Thu, 22 December 2011, 13:39:31 »
No love for the people who have full size keyboards. :P
Offline cactux
  • Topre Knight
« Reply #4 on: Thu, 22 December 2011, 13:40:39 »
Razer has one check the website
[FS]☠ The temple lol ->HERE<-
« Reply #5 on: Thu, 22 December 2011, 13:42:25 »
WASD has it on the list of things hes going to look into eventually but idk when that is actually going to happen.
Offline NguyenAdam
« Reply #6 on: Thu, 22 December 2011, 14:20:11 »
http://store.gameshark.com/viewItem.asp?idProduct=5176&idCategory=412
This would be perfect, but I don't know if it can fit a keyboard.
« Reply #7 on: Sat, 31 December 2011, 01:00:03 »
find out the measurements of the fight sticks they list would fit in it and compare them to the measurements of w/e keyboard you're going to carry.
problem solved.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Offline chel-
« Reply #9 on: Sat, 10 March 2012, 21:44:20 »
You can check http://sfbags.com/. I know they have some solutions for smaller boards.
« Reply #10 on: Sat, 10 March 2012, 23:32:12 »
I got my noppoo casea their great but a bit big especially for a TKL because its designed to fit all size keyboards ever ones with attached wrist rests. So I bought some high density foam and cut it to size for that case then cut the TKL hole out and now the case is better than ever as the foam made it stiff as well. It cost less than $10 to do, just make sure to get you r measurements right.
Offline whiskerBox
« Reply #11 on: Sat, 10 March 2012, 23:39:15 »
I use one of those sf bags and a timbuk2 messenger. I know that prolly won't work for a full size board, but I would just get a big timbuk2 bag they last forever and you can customize every little piece on it
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline anselben
« Reply #12 on: Sat, 17 March 2012, 00:56:58 »
I don't know anything about carrying cases, but when I take my keyboard places (which is rare) I just put it back in it's original box. I know not everyone keeps the original packaging but I'm very weird like that, and it turns out perfect when I take it somewhere.
Offline Weapon
« Reply #13 on: Sat, 17 March 2012, 10:03:00 »
I do the same, I pack it back into the original box.
Offline FerretBuster
« Reply #14 on: Sat, 17 March 2012, 15:50:54 »
Does anyone know anywhere in the UK that sells a bag that would fit a filco tenkeyless?
