Author Topic: Keyboard Layout 6gv2  (Read 6440 times)
Offline GoatMaster
  • Formerly Franatic89
« on: Thu, 22 December 2011, 05:07:44 »
i want to make my own keyboard layout for the steelseries 6gv2 can someone pls post the pic of the layout?
so that i can make my own and submit it to wasd keyboards!
Offline cactux
  • Topre Knight
« Reply #1 on: Thu, 22 December 2011, 05:09:30 »
what do you mean by layout? dvorak, qwerty, colemak etc
[FS]☠ The temple lol ->HERE<-
Offline GoatMaster
« Reply #2 on: Thu, 22 December 2011, 05:19:18 »
i am ne here, i just want to have a pic with the layout on it. to customize it with photoshop an submit it to wasd keyboards!
Offline byFd
« Reply #3 on: Thu, 22 December 2011, 05:19:56 »
uh, i don't think that WASD supports the special keys that steelseries has, like the enter.
i think you can just make your layout on the normal one provided by WASD. most keys should fit i think. sadly not all. pretty sure you will find more information about which do and which don't on this forum somewhere :)
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline GoatMaster
« Reply #4 on: Thu, 22 December 2011, 07:11:55 »
another question what means the keycap type selection on wasd keyboards. what is the difference between the keycap types?
Offline byFd
« Reply #5 on: Thu, 22 December 2011, 07:17:40 »
if you mean the R1 1x1, R2 1x1 etc. that is what keycap you want. the keycaps in the different rows on your keyboard have slighlty different shapes. also the modifiers are bigger etc.
if you want a full custom keycap set (all keys), then you can go to the custom keyboard designer and after you press add to cart you can choose if you want it as full keyboard or only the caps, so you don't have to fight with the different key cap types.
KBC Poker X MX Reds
Offline GoatMaster
« Reply #6 on: Thu, 22 December 2011, 10:14:07 »
but so i cannot add characters like § or the apple log etc...
Offline byFd
« Reply #7 on: Thu, 22 December 2011, 10:21:33 »
do you want to make an iso layout?
WASD wants to add ISO layout to the designer soon, i guess(hope) § will be supported then.
maybe ask your specific questions in the WASD subforum here on geekhack, they have an account here and check it quite often and answer peoples questions
KBC Poker X MX Reds
Offline GoatMaster
« Reply #8 on: Thu, 22 December 2011, 10:25:37 »
okay i will try it there! thanks for the fast answeres here!
« Reply #9 on: Thu, 22 December 2011, 12:08:48 »
You can add or upload SVG's of what you want on the keycap, and add the § that way. Alternatively, I think emailing him with your concern will also work.
This is 'cause WASD is awesome.
