Author Topic: Combine white US Filco with black DE Filco  (Read 2429 times)
Offline Amr0d
« on: Thu, 22 December 2011, 07:31:36 »
Since there is no white Filco (tkl or normal doesn't matter) with a german layout I wanted to know if it is possible to get both keyboards and then switch the board etc. to the other case? Or is there a shop where I can buy cases only? Any help is appreciated.
Filco MJ2 TKL browns | Race 75% LE reds | Phantom GH Edition soon™
HeatWare
Offline byFd
« Reply #1 on: Thu, 22 December 2011, 08:06:37 »
pretty sure case switch should work.
but not all keycaps would fit.
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline Amr0d
« Reply #2 on: Thu, 22 December 2011, 08:09:41 »
Why wouldn't the keycaps fit?
HeatWare
Offline byFd
« Reply #3 on: Thu, 22 December 2011, 08:21:27 »
[ Attachment Invalid Or Does Not Exist ] 35654[/ATTACH]
also, the special signs on the numbers are in other layout on US layout, also punctuations.
z and y are swapped, you could technically swap them, but might look weird because they are one different rows!
KBC Poker X MX Reds
Offline Amr0d
« Reply #4 on: Thu, 22 December 2011, 08:23:39 »
Well, I only wanted to switch the case. So german board with german keycaps into the case of a white filco with us board and us keycaps. So there are no caps that don't fit.
HeatWare
Offline byFd
« Reply #5 on: Thu, 22 December 2011, 08:56:55 »
ah. misinterpreted that.
well i'm not 100% sure on this but it should be possible without much problems, maybe wait for some of the modders here to answer
KBC Poker X MX Reds
Offline Tarkoon
« Reply #6 on: Thu, 22 December 2011, 09:08:12 »
I saw a white ANSI Filco TKL and a black ISO TKL open, just not at the same time. But I can't remember any difference between the two cases.
Offline N8N
« Reply #7 on: Thu, 22 December 2011, 15:39:40 »
Krylon?
seriously, I would think that painting or vinyl dyeing a keyboard case would be way cheaper than buying a whole nother keyboard just for a different color case.  Shouldn't be that hard, either, since I don't think you even need to pull the keycaps.
Offline Amr0d
« Reply #8 on: Fri, 23 December 2011, 01:01:23 »
N8N, I thought about selling the black one again since it would be nearly brand new and unused.
ripster, I was hoping to get a proper answer :( you made baby jesus cry because of that
HeatWare
