Author Topic: Lorem Ipsum  (Read 4258 times)
Offline davkol
  •  Post Editing Timeout
Lorem Ipsum
« on: Thu, 22 December 2011, 17:28:21 »
 Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
« Last Edit: Tue, 03 July 2018, 06:19:27 by davkol »
Offline Reptile
want a Noppoo Choc Mini, need an advice
« Reply #1 on: Thu, 22 December 2011, 17:47:49 »
Quote from: ripster;476225
Good luck.
Whatever you do buy the white one.
(Attachment Link) 35718[/ATTACH]
Dyesub PBT Thick Keys FTW!
+1 on the white one. I have a white one with blue switches from qtan.
Here is his store: http://www.vendio.com/stores/E-sports-Gaming-equipments
Pretty sure he ships worldwide
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline RiGS
« Reply #2 on: Thu, 22 December 2011, 18:00:14 »
I pretty sure those are lasered.
Offline RiGS
« Reply #3 on: Thu, 22 December 2011, 18:25:05 »
I bet the new Leopold PBT keys are going to be lasered as well.
Offline mr626
« Reply #4 on: Thu, 22 December 2011, 19:06:57 »
Good luck.
Hmm, I've never considered a Choc Mini before, but that photo + information on the keycaps makes me want one :-) I always thought that the non standard layout would kill it for me, but looking at it they have done a pretty good job. Unlike the SIIG Minitouch they haven't gone and put the Fn key where the left Ctrl should be, so that's something!
To the OP- I'm not sure of GNU/Linux compatibility, but hopefully someone on here can confirm. Not that it helps you with the Choc Mini, but I've used my KBC Poker under various linux distros (OpenSuSe, Ubuntu, Mint) without issue.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Thu, 22 December 2011, 19:37:59 »
I've heard of people having issues.  I only used mine for a day or so with Gentoo and had no usage issue.  However the LEDs do not light with their appropriate keys (caps/num) because of the NKRO method splitting the LEDs and the related keys onto separate keyboard controllers
Filco w/ Imsto thick PBT
Offline keyboardlover
« Reply #6 on: Thu, 22 December 2011, 20:50:55 »
Quote from: RiGS;476266
I was thinking the same...
Offline davkol
« Reply #7 on: Fri, 23 December 2011, 04:48:49 »
« Last Edit: Tue, 03 July 2018, 06:20:21 by davkol »
Offline RiGS
« Reply #8 on: Fri, 23 December 2011, 07:29:50 »
Quote from: keyboardlover;476337
Also Ron Paul leads in Iowa.
Offline Reptile
« Reply #9 on: Fri, 23 December 2011, 09:32:18 »
I use my choc mini on my pc that has chromium os; which is just another flavor of linux
Offline RiGS
« Reply #10 on: Fri, 23 December 2011, 09:49:22 »
It was 23 Dec here in Hungary.
Offline davkol
« Reply #11 on: Fri, 23 December 2011, 09:56:37 »
« Last Edit: Tue, 03 July 2018, 06:20:52 by davkol »
Offline Reptile
« Reply #12 on: Fri, 23 December 2011, 10:04:53 »
In had warranty card in the box from qtan. I dont know how Noppoo handles stuff like that though.
Offline RiGS
« Reply #13 on: Fri, 23 December 2011, 12:15:18 »
IIRC reaper returned his Rapoo to qtan without any troubles.
Offline Human
« Reply #14 on: Fri, 23 December 2011, 13:16:24 »
Quote from: ripster;476637
Chin[strike]ese[/strike]a warranty cards.
Lol.
Fixed
Offline pitashen
« Reply #15 on: Fri, 23 December 2011, 13:21:21 »
Quote from: Reptile;476633
probably no oversea customer service to speak of.
Offline VR4
« Reply #16 on: Sun, 25 December 2011, 13:09:54 »
Does the smaller shift key on the right give you guys any issues?
Offline RiGS
« Reply #17 on: Sun, 25 December 2011, 14:05:10 »
I can imagine it could stick with mx browns when hitting at the corners as it doesn't have any stabilizing.
