Author Topic: Blank black model m keys - should i make more?  (Read 1882 times)
Offline dem0critus
« on: Sat, 24 December 2011, 14:02:20 »
moar?
Offline BiNiaRiS
« Reply #1 on: Sat, 24 December 2011, 17:28:26 »
you can buy a full set of black blank keys from Unicomp for $20. What would be the benefit of yours over those?
KMAC 2 w/ErgoClears
Offline dem0critus
« Reply #2 on: Sat, 24 December 2011, 18:05:34 »
well, they're free first, 2nd they're made from das keycaps, so they feel different and have a different profile.
To be honest, I don't really like the way black keys look on a model m, so I wanted to get another opinion before abandoning the project.
« Reply #3 on: Sat, 24 December 2011, 23:55:46 »
Quote from: dem0critus;477335
They looks pretty good on a unicomp, so the project should not be abandoned.
Also note that the Model M keys are all the same profile (the curve is in the mounting) so if you put profiled DAS keys on it, you'll end up with a different profile.
Offline jpm804
  • KeyCap Assasin
« Reply #4 on: Sun, 25 December 2011, 06:29:56 »
Quote from: BiNiaRiS;477325
I would have to agree with bini and say better off with getting them from unicomp and save yourself the time and hassle of converting the dad keycaps...
Also not a fan of the black blank keycaps on a white model m unless it's got an industrial top or just the original industrial m...
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline NorrisB
« Reply #5 on: Sun, 25 December 2011, 11:26:49 »
those look like ****
