Author Topic: Is the Unicomp keyboard the right direction for me?  (Read 1422 times)
Offline iBro
« on: Mon, 26 December 2011, 18:07:41 »
Hello all. I have been using my Leopold keyboard with MX browns for close to a month now, and I have a confession to make. The brown switches just don't seem to be all they were hyped up to be. Don't get me wrong, they are infinitely better than my old rubber dome, but I have issues the with tactility of them. The small bump that comes with the brown switches seems almost useless to me while typing at a respectable speed. Even when I pay attention and don't hammer each key, the bump still isn't noticeable and doesn't offer me any feedback to if they key has actuated or not.
At this point I would be very interested if anyone else shares my opinion on the brown switches.
Now on to the Unicomp. My conclusion after using the browns is that I might want to try a keyboard with a stronger tactile feel, so that it is more noticeable and useful when typing. I have read that the buckling springs are the best when it comes to tactility. But having not used a buckling spring keyboard, I would like to hear from you how much more tactile the Unicomp is compared to the browns.
I would also like your opinions on the Mx Red switches. Because of course, another conclusion to this could be that I'm totally wrong about tactile bumps in any keyboard, and they are just not for me, which would lead me to try reds.
Unicomp Space Saver (buckling spring) Silicon Graphics (dampened cream alps) KBC Poker (ghetto reds)
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #1 on: Tue, 27 December 2011, 01:08:19 »
Well in Buckling Springs it's hard to call this tactile feel a bump. It's more of a cliff, much sharper than any other mechanical. The spring buckles at about 3 mm of key travel, then it feels like the key falls to the very bottom but in fact there is still some resistance so it is possible to type without bottoming out.
Offline iBro
« Reply #2 on: Tue, 27 December 2011, 01:14:06 »
Thank you Czarek for the clarification on the type of tactile feedback the Buckling spring gives compared to the blues. But is this tactility far more pronounced than that of the blues? Is it sharp enough to be noticeable, and more importantly, useful while typing at normal speeds?
Essentially I want to know if a tactile switch would even be useful for me at all. I don't ever see myself not bottoming out while I type, so should I just opt for a linear switch instead?
« Last Edit: Tue, 27 December 2011, 01:20:04 by iBro »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Tue, 27 December 2011, 03:03:25 »
Like I said in your other thread, tactility is more about feel than utility.  The aptly-described "cliff" tactile feel of buckling springs is waaay more pronounced than either blues or browns. I enjoy both blues and BS, but don't really care for browns much.
