Author Topic: Integrated pointing device, help me choose  (Read 1954 times)
Offline svet
« on: Tue, 27 December 2011, 13:24:23 »
I am looking for a mechanical keyboard with an integrated pointing device that does not require me to move the hand away from home row too much. (there are quite a few keyboards with a trackball or touchpad above or below the numpad, which is not what I am looking for).
So far the only one I have found is the unicomp endurapro, which comes with a ibm-style "nipple mouse". However, it uses buckling springs, which I am afraid might be too noisy, and the mouse is reviewed as the worst part of it, apparently being too stiff and with a noticeable dead zone.
I have found a couple other keyboards with a touchpad below the spacebar, but they use rubber domes.
Are there other choices? preferably with capacitive or brown switches. Available in the EU is a plus.
Offline czarek
  • Keep the momentum going!
    • FalbaTech
Offline svet
« Reply #2 on: Tue, 27 December 2011, 13:47:07 »
I only have cash, and all the ones on clickykeyboards are sold :(
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #3 on: Tue, 27 December 2011, 14:11:26 »
i use a TKL ibm space saver II (ibm p/n 37l0888, iirc). it's rubber dome, but so is the m4-1 (and with reduced travel, to boot), and the new lenovo/thinkpad travel keyboards are all chiclet, which i'm not too crazy about (although i have one of those too). the advantage of the newer trackpoint IV based boards is that the nub is much more responsive than the old-style trackpoint II on the M13, or the resistive type on the unicomp board.
another integrated device that i've found to be pretty reasonable is the multitouch + chicklets on the macbook pros, largely because of gestures.
in summary, you're not going to get mechanical + a good pointing device unless you build it yourself, so pick which aspect is most important to you. personally, when i'm working in an IDE, i go with the SSII. when i'm not forced to deal with some horrible mouse based GUI, i use my filco tkl with blues.
Offline czarek
    • FalbaTech
« Reply #4 on: Tue, 27 December 2011, 14:27:58 »
I can say Endurapro is good enough for programming work (selecting text, scrolling) and internet browsing, sure nowhere as good as IBM/Lenovo but surely usable.
There is other problem I have with the pointing stick in keyboard. When I type pretty fast my fingers glide very low above the keys and the stick simply gets in a way. It's less noticeable on Lenovo laptops as the keys are low profile and flat but on Endurapro (and I believe M13 as well, but I haven't tried it) it is annoying.
Offline svet
« Reply #5 on: Tue, 27 December 2011, 15:19:52 »
is there a starting point if I wanted to build one myself? can you buy pointing sticks separately? they're so hard to find even with a keyboard included.
maybe a separate trackball kept under the spacebar could be operated with thumbs alone if it's small enough. Do you know of any that might work this way?
Offline mkawa
« Reply #6 on: Tue, 27 December 2011, 18:10:07 »
this is one of those situations where if you have to ask, the answer is clearly no.
Offline shrap
« Reply #7 on: Tue, 27 December 2011, 18:12:10 »
Quote from: svet;478559
RollerMouse
Review on GH
Offline svet
« Reply #8 on: Wed, 28 December 2011, 15:42:06 »
Look at this beast:
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=24
a Maltron that has a similar layout to the advantage, plus trackball, a lot of extra keys and a pricetag that is worth a small continent. I have found no reviews. How are the switches? does the trackball in that position work well with that layout?
Offline sordna
« Reply #9 on: Wed, 28 December 2011, 15:49:51 »
By far the best integrated pointing device ever on a keyboard is the one on the Fingerworks Touchstream, the entire keyboard surface being a touchpad whihc works amazingly well. You can point, drag, stroll right where your hand is, just by putting 2 or more fingers on the board. I don't like typing so much on this board, but the mousing is the best of the best. Here's mine:
[ Attachment Invalid Or Does Not Exist ] 36098[/ATTACH]
The TG3 is pretty good too, surprised nobody mentioned it:
http://geekhack.org/showwiki.php?title=Island:20454
However it would be great if we ever see the mini-guru materialize:
http://www.guru-board.com/
Another prototype that might get a trackpoint is the ErgoDox:
http://geekhack.org/showthread.php?22780-Interest-Check-Custom-split-ergo-keyboard
