Author Topic: What can I expect from MX Red, black or clear switches coming from...  (Read 2163 times)
Offline Riley
What can I expect from MX Red, black or clear switches coming from both Blues and a Model M? I like the feeling of both keyboards, I like the clickyness and the noise, but I'm up to try something new, I just don't want to buy a new keyboard and it not feel like a true mechanical keyboard, but just a rubber dome.
O, and I haven't bought a mechanical keyboard in over a year, so whats up with this KBC poker keyboard? And why is it like 40%? Does that mean its 40% the size of a normal keyboard, or 40% mechanical?
« Last Edit: Thu, 29 December 2011, 14:30:39 by Riley »
Offline REVENGE
« Reply #1 on: Thu, 29 December 2011, 14:37:25 »
ping
Offline Riley
« Reply #2 on: Thu, 29 December 2011, 14:39:30 »
huh?
Offline REVENGE
« Reply #3 on: Thu, 29 December 2011, 14:49:09 »
You can expect less tactility. That's significantly less tactility from the Clear switches and no tactility from the Red / Black since they are linear. No mechanical keyboard will feel quite like a rubber dome board, but aside from that anything goes. As for the Poker, you can find a bunch of great reviews if you search in the review section (including one from me, Cherry Blue version). The 40% refers to the layout, it's exactly the size and keys from the main alphanumeric section of your keyboard, everything is still mechanical. If you want a nice portable keyboard to take with you on the go, I would consider a Poker with Cherry Blues.
It also pings.
Offline Riley
« Reply #4 on: Thu, 29 December 2011, 21:23:17 »
So, how do they make it 40% smaller? by just cutting off the arrow keys and num pad? or do they do that and also make everything smaller so it feels like i'm typing on a phone?
I still don't know what you mean by ping, the only thing I know that ping stands for is to ping an ip.
Offline mkaresh
« Reply #5 on: Thu, 29 December 2011, 21:53:14 »
New here and to keyboards, but I believe the 40% refers to the number of keys, 40% of the standard 104. No separate keys for most functions, numbers, etc. Letters and keys to toggle the keys to yield something other than a letter (embedded numpad, etc.).
Offline Tony
« Reply #6 on: Thu, 29 December 2011, 21:54:10 »
Like sex, you will not know how it feels until you try it.
« Last Edit: Thu, 29 December 2011, 22:01:54 by Tony »
Offline flyball
« Reply #7 on: Thu, 29 December 2011, 22:10:05 »
read the wiki and the reviews
[SIGPIC][/SIGPIC]
Offline noodles256
  • le legendary
« Reply #8 on: Thu, 29 December 2011, 22:12:21 »
Quote from: Riley;479730
you have same name as one of my dogs
AF | Ducky YOTD |
Offline Riley
« Reply #9 on: Thu, 29 December 2011, 22:23:19 »
That happens quite a bit.
Offline pitashen
« Reply #10 on: Thu, 29 December 2011, 22:31:56 »
Quote from: noodles256;479977
Offline REVENGE
« Reply #11 on: Fri, 30 December 2011, 01:26:08 »
Quote from: Riley;479951
I refer you to the reviews because they should answers your questions. If you need a size comparison, read my review and you'll see exactly how big it is compared to a more or less standard keyboard.
Offline REVENGE
« Reply #12 on: Fri, 30 December 2011, 01:27:51 »
And here's the shameless self promotion: http://geekhack.org/showwiki.php?title=Island:19607
I think qtan is still using the pics he jacked from my post for his eBay listings.
