Author Topic: Pink Majestouch Tenkeyless  (Read 1847 times)
Offline hyoseke
« on: Thu, 29 December 2011, 14:43:55 »
Hi,
I tried posting this in the vendor forums but I didn't have any luck there. I hope its not a repost (i did a search).
I can only find the pink majestouch tenkeyless in black and brown switches. Does anyone know where I can find them in blue? Or if they are even made in blue?
If not, any idea if diatec is planning on making a blue switch version?
It seems I cant post links. This is the metallic pink keyboard with white keycaps.
Thanks
Offline Tony
« Reply #1 on: Fri, 30 December 2011, 01:47:06 »
Links can be posted without http://, such as google.com or geekhack.org.
Offline Human
« Reply #2 on: Fri, 30 December 2011, 02:06:47 »
@TS:
I assume you mean FILCO LOTUS. It is a China Exclusive board.
Offline reaper
« Reply #3 on: Fri, 30 December 2011, 02:20:16 »
Quote from: hyoseke;479741
Good luck find one with blue switch.  Others have tried. Me, I'm happy with brown. =D
« Last Edit: Fri, 30 December 2011, 02:26:17 by reaper »
Din Eli
Offline hyoseke
« Reply #4 on: Fri, 30 December 2011, 04:14:31 »
Thanks for letting me know tony.
Here is the exact link: leopold.co.kr/?doc=cart/item.php&it_id=1312865103
From the responses it seems that this keyboard is not available in blues :(. In that case, does anyone know if diatec has any plans to release it in blues?
Thanks
Offline Human
« Reply #5 on: Fri, 30 December 2011, 04:53:12 »
Quote from: hyoseke;480097
Thanks
Hmm, so there is non-lotus version of such keyboard...
BTW,
1. Buy a that keyboard with brown switch
2. Buy another FILCO TKL with blue switch
3. Swap them and resell the one you don't want
4. Profit?
