Author Topic: How do I remove the big keys on my Steelseries 7G? (Shift Key specifically)  (Read 7361 times)
Offline Russ369
I dont have an actual key cap remover, ive managed to remove the single keys but the left shift seems tricky, is there special instructions on how to do it?
Offline whiskerBox
« Reply #1 on: Fri, 30 December 2011, 17:39:31 »
Yeah there is instructions may I recommend the Wiki
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Sat, 31 December 2011, 05:24:48 »
Those have cherry stabilizers so u have nothing to worry about just get a key puller or 2 an pull strait up should pop off easy enough, might be able to do it by hand if you have all the othe keys off.
