Author Topic: Looking for an outstanding Cherry MX Brown keyboard.  (Read 4479 times)
Offline Japex
« on: Sat, 31 December 2011, 20:06:52 »
Well, as of now I have a fairly decent budget of somewhere around $150. This will be my first mechanical keyboard outside of an old IBM keyboard that my Dad owns. I've decided the Cherry MX Browns would be the best choice seeing as I'm going to be doing lots of typing and a bit of gaming. Before I knew about switch types and what not I was looking into a Happy Hacker Keyboard Lite2 but I've decided that would be a waste of money. Now I currently have my eye on a Filco Majestouch 2 Tenkeyless but I'm not sure if it's the best bang for my buck.
So if any of you could suggest something better (if there is anything better) that would be nice.
Offline reaper
« Reply #1 on: Sat, 31 December 2011, 20:09:26 »
Since this is your first post, welcome to Geekhack. =)  And you can't go wrong with a Filco...  really.  Also good call on that HHKB Lite 2.  If you like the size, save up and get the real HHKB Pro 2.  One of the best keyboards ever, imo. =P
« Last Edit: Sat, 31 December 2011, 20:15:16 by reaper »
Din Eli
Offline sordna
« Reply #2 on: Sat, 31 December 2011, 20:13:04 »
How about a semi-custom or custom WASD keyboard ? They're getting excellent reviews around here.
Offline Japex
« Reply #3 on: Sat, 31 December 2011, 23:33:10 »
Quote from: sordna;481228
How about a semi-custom or custom WASD keyboard? They're getting excellent reviews around here.
I'm just exactly sure about the quality of these and I don't see any specific details about switch types, etc. but the overall concept seems cool.
Offline Creizai
« Reply #4 on: Sun, 01 January 2012, 00:12:18 »
Quote from: reaper;481227
God I want that setup so much....
Offline False_Dmitry_II
« Reply #5 on: Sun, 01 January 2012, 01:14:12 »
... The quality is just fine and the switches are still switches.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #6 on: Sun, 01 January 2012, 03:10:42 »
Quote from: Japex;481226
I would sugestg a leopold tkl and a HHKB pro 2
their greatboard but they wont have a tkl fo a while.
Quote from: Creizai;481317
The get it?
Offline Tony
« Reply #7 on: Sun, 01 January 2012, 06:28:57 »
I am using a Filco brown at work and it's excellent. WASD is fine too with customized keycaps.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Sun, 01 January 2012, 10:58:22 »
If you like the HHKB, but can't afford it, perhaps the KBC Poker is for you? It's the closest to a HHKB in Cherry MX and only cost about $80 for the standard abs keycaps version. Not better build quality than Filco, but a very good keyboard. It's the best Cherry mini keyboard around in my opinion.
« Reply #9 on: Sun, 01 January 2012, 20:59:03 »
Or, make a DOX!
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #10 on: Sun, 01 January 2012, 22:32:20 »
G80-3484HKCUS-2 for doubleshot browny goodness. But you will need to use a taobao agent. I personally hate browns. I'm a red and clear kinda guy. And yes, I do realize that those are both the lightest and toughest switches. I'm just weird I guess. But that is a plus here.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline Deverica Wolf
  • My name is Hack, Geek Hack.
    • Head-Fi
« Reply #11 on: Mon, 02 January 2012, 18:50:03 »
Either go with Filco or WASD. I have a Filco Brown and it's quality is amazing. Some people think WASD is even better but they don't sell a Tenkeyless.
UNICOMP.Spacesaver BS  |  FILCO Majestouch-2 TKL  |  FILCO Majestouch-2  [-_-]~ TKL  |  FILCO Majestouch-2 TKL
FILCO Majestouch-2 TKL  |  Deck Legend - ToXic  |  CHERRY Touchboard ITA
Offline Japex
« Reply #12 on: Thu, 05 January 2012, 15:36:37 »
I ended up purchasing the Filco. Now I'm just hoping that I won't have any trouble with this switch type seeing as I will be playing some MMOs and I'm only used to rubber dome keyboards.
« Reply #13 on: Thu, 05 January 2012, 17:16:27 »
Quote from: Japex;484018
If you  do give it a week or 2 and you should be used t it by then.
Offline mechanisch
« Reply #14 on: Thu, 05 January 2012, 18:14:02 »
Quote from: TheProfosist;484094
It really is amazing how we adjust.  I busted out my old Logitech G15 yesterday just for curiosity and tried typing on it.  I was shocked at how awful and "different" it felt after only a couple weeks using mechanicals.  I mean, I enjoyed my transition to mechanical switches immediately but it wasn't until I tried typing on rubber domes again after a few weeks that I could truly appreciate the difference and know I would never, ever be going back.
Japex, I believe the Filco is a great choice, and out of all three of my boards is easily the "best" in terms of quality and type experience.  It just feels so solid and smooth to type on.  Enjoy!
Offline NorrisB
« Reply #15 on: Thu, 05 January 2012, 22:26:31 »
Why not go leopold?
Offline sordna
« Reply #16 on: Thu, 05 January 2012, 22:31:20 »
Both WASD and Filco are probably better than the current Leopolds (which got reports of controller and usb connector problems recently).
Offline NorrisB
« Reply #17 on: Thu, 05 January 2012, 22:37:27 »
Quote from: sordna;484341
where did you read that?
Offline NorrisB
« Reply #18 on: Thu, 05 January 2012, 22:39:29 »
you know your ****
Offline NorrisB
« Reply #19 on: Thu, 05 January 2012, 22:51:43 »
done and done
Offline Japex
« Reply #20 on: Sat, 07 January 2012, 16:28:45 »
The keyboard is finally here and this thing is ****ing amazing. It's as if I'm typing on a pile of boobs. Each keypress is so light and accurate and the sounds that it produces are outstanding. My hands never seem to tire while typing on this bad boy. I think I'm in love. Even now I'm typing out long paragraphs just so I can constantly type on this board. I'm very happy with my purchase. :3
