Author Topic: Looking for a mechanical keyboard with nordic (swe) layout.  (Read 2474 times)
Offline Iridium
« on: Sun, 01 January 2012, 15:28:12 »
Hello guys!I am looking for a mechanical keyboard, preferably illuminated and with a swedish/nordic layout. I have looked alot at the Cherry MX switches but other switches will work too. My bugdet is somwhere around 100 USD(700 SEK), suggestions?
Offline EDI
« Reply #1 on: Sun, 01 January 2012, 19:28:49 »
Do you more prefer keyboard with or without keypad?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 01 January 2012, 20:55:34 »
Illuminated and SE mechanical, I believe narrows it down to the Mionix Zibal60, qpad MK and razer black widow. Not sure about the pricing in your area, but all probably more than budget. Cheapest option for you would probably be a Cherry G80, but not backlit. Other non backlit in SE are Filco, Zowie Celeritas. Not sure if others exist, but I have seen all of these in Nordic as a standard option.
Offline Iridium
« Reply #3 on: Mon, 02 January 2012, 15:11:49 »
Thank you for the answers! All of the illuminated keyboards are out of my budget but ive heard some good things about Filco's so i guess i'll just get one of those
« Reply #4 on: Mon, 02 January 2012, 16:07:17 »
Filco is always a good choice. I think you will enjoy it more than any of the backlight ones in the long run.
Offline Ekaros
« Reply #5 on: Mon, 02 January 2012, 18:36:53 »
Generaly Filco's are more than others.... I couldn't find G80 in SWE/FIN...
Qpad MK, Razer BW Ultimate and Corsair brings to mind where there is some backlighted options. Still, for cheap options normal Blackwidow or Steelseries 6Gv2, it's not too bad atleast in Finland anymore...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Iridium
« Reply #6 on: Sun, 08 January 2012, 06:50:34 »
I ended up buying Qpad MK-80 pro, it was a bit over my budget but i think it's worth it.
