Author Topic: How to remove the case of a leopold?  (Read 1850 times)
Offline lightsout714
« on: Sun, 01 January 2012, 18:38:20 »
Considering plasti-dipping the top case of my white leopold (tkl). I see some little clips but I don't want to mess anything up as I am not sure if I like the clears and may end up selling this.
Offline Crowat
« Reply #1 on: Sun, 01 January 2012, 23:27:45 »
Remove the three screws.  The center one is under the do not remove sticker.
Then I started from the middle (above the USB plug). I used three credit cards and would wedge my way across slowly.
Keep going at it slowly.
« Reply #2 on: Mon, 02 January 2012, 09:38:08 »
Thank you sir I appreciate it!
