Author Topic: PBT Keycaps  (Read 2010 times)
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
PBT Keycaps
« Reply #1 on: Mon, 02 January 2012, 12:05:41 »
It's not a bad deal.  They just look like your typical KBC keycaps.  Can't go wrong with a US seller that has 100% feedback.
Offline Crowat
PBT Keycaps
« Reply #2 on: Mon, 02 January 2012, 12:36:56 »
Lol Ripster I feel like your posts are 80% content 20% troll...
I picked up a set of orange ones.  With my green ESC key I need to be careful to avoid the MM effect...
Offline lightsout714
PBT Keycaps
« Reply #3 on: Mon, 02 January 2012, 12:38:52 »
Quote from: Crowat;481894
I think you got it flipped around :tape:
Offline DanGWanG
  • Higher Standards
PBT Keycaps
« Reply #4 on: Mon, 02 January 2012, 12:44:29 »
Quote from: lightsout714;481897
Tru dat.
PBT Keycaps
« Reply #5 on: Mon, 02 January 2012, 14:07:09 »
Only 20% ? compliments like that tend to get added to his signature.
While that might not hold true for his posts, his wiki articles can exhibit a similar composition to the one you postulate.
Offline jellowiggler
PBT Keycaps
« Reply #6 on: Mon, 02 January 2012, 14:19:30 »
:-P
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
