Author Topic: Das vs Filco Majestouch key size.  (Read 4717 times)
Offline Schalken
« on: Mon, 02 January 2012, 07:05:34 »
Short:
Are the keys on the Filco Majestouch bigger/further apart than on the Das Keyboard?
Long:
I recently purchased a CM Storm Quick Fire Rapid (Cherry MX Blue) to replace my broken Das Keyboard (Cherry MX Brown) but had to return it for two reasons:
The blue switches are stupidly loud. As in disturbs-the-peace/hurts-your-ears kind-of loud. They are also very stiff. I know it's only 5cN over the browns, but it made a huge difference to me. The way the actuation point and reset point aren't the same also feels...strange, like the key gets stuck after you've pressed it. My brain couldn't cope with the idea that after all the effort put in to make it click, I have to lift my finger higher than the point it clicked to have it un-click. Exhausting! :P
The keyboard also felt a lot bigger than the Das. My fingers wouldn't move far enough to hit the keys in the center, and would hit them on the edge instead, and so in combination with the higher actuation force a lot of key presses would be missed. It feels about the same size as a MacBook Pro keyboard, and I'm sure the Das was smaller. However, I'm not sure how much of my discomfort is due to the difference in size or the different switches.
I do love the form factor though. No wasted space.
Now my understanding is that the Quick Fire Rapid is the exact same casing as the Filco Majestouch. If that's the case, then the keys are likely to be the same distance apart, correct? Has anyone else found the keys on a Filco Majestouch to be bigger/further apart than on a Das? Is there much of a difference? I can't seem to find it mentioned on the Internet anywhere.
Offline Human
« Reply #1 on: Mon, 02 January 2012, 07:36:01 »
Quote from: Schalken;481785
Short:
Long:
Offline itlnstln
« Reply #2 on: Mon, 02 January 2012, 07:43:03 »
Short:
Short:
No.
Long:
No.
Offline pitashen
« Reply #3 on: Mon, 02 January 2012, 12:10:07 »
Offline pitashen
« Reply #4 on: Mon, 02 January 2012, 14:33:40 »
Offline itlnstln
« Reply #5 on: Tue, 03 January 2012, 04:05:34 »
Quote from: pitashen;481945
http://answers.yahoo.com/question/index?qid=20081110205503AAvdblg
Ha!  In line with the "fat pad" response...
IIRC,the Das has a little bit of a front lip, and that might be jacking with the OP's perspective a bit.
Offline Schalken
« Reply #6 on: Tue, 03 January 2012, 06:52:22 »
So I was reading the specs on the Filco and it mentioned "Key pitch: 19mm". Key pitch! That's what I should measure. I measured the key pitch on my MacBook Pro...exactly 19mm. Makes sense, the QuickFire Rapid felt the same size. I measured the key pitch on my broken Das (I don't know why I hadn't already)...exactly 19mm.
So you're right, and I'm completely stumped as I have always thought my MacBook Pro's keyboard was "too big" and the Das was "just right". Maybe the feeling comes from the key caps, but at least now I know the keyboards aren't actually different sizes, and my dissapointment with the QuickFire Rapid can be attributed to the MX Blues. So a Filco with MX Browns should be great.
Thanks for your help! :)
Offline kiczek
Re: Das vs Filco Majestouch key size.
« Reply #7 on: Sat, 27 April 2013, 00:19:54 »
Blah Wrong Thread
« Last Edit: Sat, 27 April 2013, 00:21:30 by kiczek »
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Sat, 27 April 2013, 00:33:25 »
Well personally I owned a Das and Filco and I find they feel the same dimensionally.  However I guess I could bust them out and measure it scientifically........  but I'm too lazy now maybe tomorrow  :P
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #9 on: Sun, 28 April 2013, 22:00:07 »
i have both and if you closed your eyes and touched both, you wouldn't know the difference. (key length and space)
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
« Reply #10 on: Mon, 29 April 2013, 08:23:26 »
"Pitch" (ie the distance between keys, from center-to-center) must be the same at 3/4" for standard keyboards.
However, the perception of spacing can vary widely with the profile of the keys. For example, I am an IBM Model M/F user, and these keys are quite tall and tapered, so that the perception is that they are far apart.
Than is an illusion, however, the pitch is still 3/4" and it is simply the look and feel of the "plateaus" that you perceive, and which make you ignore the "valleys" in between. Lower (less tall) keys usually seem much closer together, but they aren't.
I suppose that I have big clumsy fingers, and typing on my phone, for example, is very difficult and frustrating for me, because the "keys" are tiny rectangles that are immediately adjacent to each other. I would be much happier if they were square and had zones of dead space around them, but that is my problem, I suppose.
- D Trump 2026-10-24
Offline Bry
« Reply #11 on: Mon, 29 April 2013, 10:32:39 »
Some keycaps are tapered more, so the actual top surface is smaller. I know the Filco caps are tapered more than the xarmor board I had a few years ago.
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
Offline TreeSc2
« Reply #12 on: Mon, 29 April 2013, 22:38:40 »
I love my das and my filco, id probably still use my das if I didnt order the ultimate blank like an idiot :P
Offline daerid
    • Rossipedia
« Reply #13 on: Wed, 01 May 2013, 09:29:16 »
What's wrong with the ultimate blank? That was a Costar board, excellent quality.
Offline esoomenona
  • Gnillort?
« Reply #14 on: Wed, 01 May 2013, 09:31:48 »
He probably needs to look down every once in awhile to get his bearing. Understandable.
