Author Topic: Access keyboards  (Read 25071 times)
Access keyboards
« Reply #100 on: Sun, 22 January 2012, 13:01:53 »
Quote from: fossala;496279
Hmmm, something is strange here. I don't know what happend so all I can do is apologize, I should of checked them more thoughtfully. Just checked mine and some of mine aren't doubleshot, enter, caps lock and f5.
Nah, it's okay. It was said that most of the F-keys aren't usually doubleshot. I went in for the matrix layout. Doubleshot keys and NKRO are just bonuses.
I'm a bit concerned, though, because it's not working on my adapter. The light flashes twice, but I get nothing when I type. Also, can you reprogram it across a USB to PS2 adapter, or do I need to install windows on my computer with PS2?
fossala
  •  Guest
Access keyboards
« Reply #101 on: Sun, 22 January 2012, 13:14:19 »
Try and press the top left hand key. On one of the boards I checked if they could be programmed by making one black except the top left key, then forgot which one.
I don't know if it can be programmed with an adapter but it shouldn't be to hard to find a PC with a PS2 port.
Offline IvanIvanovich
  • Mr. Silk Underwear
Access keyboards
« Reply #102 on: Sun, 22 January 2012, 13:17:47 »
I strongly recommend to use real ps/2 port for programming. Adapter will likely cause a problem if it even work at all.
I also bought it for programmable matrix, any other feature is bonus in my eyes too. At the price it was sold for I am amazed it is 100% function, let alone so nice.
HAHA you erased the program, so all key do nothing. I bet thats the one you got dorkvader.
« Last Edit: Sun, 22 January 2012, 13:20:10 by lysol »
Offline pyro
Access keyboards
« Reply #103 on: Sun, 22 January 2012, 13:20:09 »
One of mine doesn't work, the other one only works if connected directly to the ps2 port of the motherboard. They don't work through an ps2->usb adapter.
fossala
  •  Guest
Access keyboards
« Reply #104 on: Sun, 22 January 2012, 13:21:37 »
Quote from: pyro;496302
They where all tested before being shipped.
Access keyboards
« Reply #105 on: Sun, 22 January 2012, 13:22:26 »
It should work through an ACTIVE adapter after programmed. It won't work with those dumb purple/green ones.
Offline Hzza
Access keyboards
« Reply #106 on: Sun, 22 January 2012, 13:41:22 »
I bought mine for the keys and couldn't get along with the matrix layout so if someone wants another board PM me and you can have mine for however much it costs me to post it.
Offline hoggy
  • * Ergonomics Moderator
Access keyboards
« Reply #107 on: Mon, 23 January 2012, 01:42:22 »
Try plugging the dead one in to the motherboard and leaving it for around ten minutes.
The blue cube adaptor works on all of my access boards.
Access keyboards
« Reply #108 on: Mon, 23 January 2012, 01:57:11 »
Quote from: lysol;496304
I'm using a PS2 to USB adaptor with both a unicomp (was a gift, they got PS2 by mistake) and a WASD through an adapter at once (saves a USB port).
It's not "hard" to find a computer with a PS2 port, I have 4 in my room, just none have windows on them (and only a few technically "work") I'm going to just shut down my windows box and swap the HDD over into one of them and borrow a monitor for the programming :p
I just had to unplug and the replug the adapter from the USB port, no idea why, but it works now.
I like how "cancel" maps as [ and there is a key labelled with period and semicolon. (comes out as "v" and "V" in Dvorak). "clear" seems to be backspace.
Offline kbdfr
Access keyboards
« Reply #109 on: Mon, 23 January 2012, 02:48:01 »
Haven't got anything yet.
Apparently shipping is faster from the UK to Canada than to Germany - or my keycaps got lost.
Offline fuah
Access keyboards
« Reply #110 on: Mon, 23 January 2012, 08:21:08 »
Quote from: Hzza;496313
PM'd!
fossala
  •  Guest
Access keyboards
« Reply #111 on: Mon, 23 January 2012, 11:17:24 »
Quote from: kbdfr;496652
They turned up at my house today as "returned to sender". Don't know why, I will try and send them out again on Wednesday (my next day off work).
fossala
  •  Guest
Access keyboards
« Reply #112 on: Mon, 23 January 2012, 11:17:48 »
Quote from: fuah;496725
PM'd!
Can people stop pm'ing me. I don't have any left.
Offline hoggy
Access keyboards
« Reply #113 on: Mon, 23 January 2012, 14:15:29 »
Quote from: fossala;496825
Ha ha ha ha!  I got pm's for months after selling my first batch.
Offline fuah
Access keyboards
« Reply #114 on: Mon, 23 January 2012, 18:04:47 »
How's a dude supposed to know?!
haha..
fossala
  •  Guest
Access keyboards
« Reply #115 on: Tue, 24 January 2012, 00:33:41 »
On that note I may be selling a handfull of keyboards. If I decide too it will include my access and my tipro.
Offline Icarium
  • I AM A MONKEY!
Access keyboards
« Reply #116 on: Tue, 24 January 2012, 01:44:41 »
Quote from: fossala;497372
dibs
I had a sig once but it's gone. It used to display an icon of a Kinesis. Just imagine that.
Offline kbdfr
Access keyboards
« Reply #117 on: Tue, 24 January 2012, 02:01:08 »
Quote from: fossala;496823
Thanks for the update, fossala. And again, time doesn't really matter ;)
Offline 7bit
  • MX1A-G1DW
Access keyboards
« Reply #118 on: Tue, 24 January 2012, 06:29:29 »
Quote from: pyro;495224
Got mine yesterday, thanks fossala!
But howtf did they treat these keyboards ಠ_ಠ
I also found nails in them.
That is some kind of new record.
I found a lot of that stuff in keyboards which had been used in boutiques, but this is much more than I've ever seen.
It is not harmful (contrary to Pharmacy keyboards), but be careful with the needles!
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline kbdfr
Access keyboards
« Reply #119 on: Thu, 02 February 2012, 05:45:25 »
Any updates? Still haven't got anything :(
Access keyboards
« Reply #120 on: Thu, 02 February 2012, 07:51:12 »
I thought shipping to Germany from UK was generally pretty quick? Maybe it's held up in customs.
fossala
  •  Guest
Access keyboards
« Reply #121 on: Thu, 02 February 2012, 12:29:01 »
Quote from: kbdfr;506245
No I didn't send them with tracking... If it doesn't turn up soon all I can do is refund you and apologies.
