Author Topic: What WASD row to choose in order to match SP row 3 profile ?  (Read 4183 times)
Offline zulios
« on: Mon, 02 January 2012, 16:33:08 »
Hello everyone,
I just read in the wiki that WASD caps have a higher profile than SP ones. But would anyone know what would be the closest choice when ordering WASD caps to get a matching profile with SP row 3 caps ?
Any help would be greatly appreciated.
Tipro matrix - mx black
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Mon, 02 January 2012, 16:44:20 »
I have both on one of my Pokers SP profile for alphas, WASD for all of the keys larger than 1 unit. ` row is about 1mm higher. Q row is so close to same you can only barely tell, maybe .3mm higher. A row is about 1mm higher. Z row is same on side closest to you, but SP have more slant away and is about 1mm lower in that edge.
Offline zulios
« Reply #2 on: Tue, 03 January 2012, 07:10:19 »
Great information, thanks :)
