Author Topic: Check out Unicomp's new keyboard configurator tool!  (Read 2302 times)
Offline NormaJean
« on: Thu, 05 January 2012, 14:46:55 »
http://www.pckeyboard.com/mm5/merchant.mvc?Screen=BASK
So far all the keyboards I have made are free :D
Enjoy it while it lasts!
edit: A price appeared at the end :(, still I don't know if anyone had mentioned Unicomps' new website...
Offline Warduke
Unicomp Customizer 104 - Rosewill RK-9000 - CM Storm QuickFire Rapid - CM Storm QuickFire Stealth -
Pok3r
Offline Internetlad
« Last Edit: Thu, 05 January 2012, 15:20:52 by Internetlad »
"Beep . . . Beep . . . Beep" -Sputnik I
Offline NormaJean
« Reply #3 on: Thu, 05 January 2012, 15:46:21 »
I fail
Offline NorrisB
« Reply #4 on: Thu, 05 January 2012, 22:36:44 »
Quote from: Internetlad;484003
2 dollars for an IBM single button mouse. What value!
Also wtf is the difference between http://www.pckeyboard.com/mm5/merchant.mvc?Store_Code=PCK&Screen=PROD&Category_Code=UltraClassic&Product_Code=UNI0P4A and http://www.pckeyboard.com/mm5/merchant.mvc?Store_Code=PCK&Screen=PROD&Category_Code=UltraClassic&Product_Code=UNI0P4A other than 14 dollars?
no difference there they even have the same code
