Author Topic: Stuck spacebar  (Read 1244 times)
Offline Son of Gnome
Stuck spacebar
« on: Thu, 05 January 2012, 21:22:52 »
Hey my friends blackwidow has its space bar stuck on the right side. the left side works fine but the right side is stuck. Is there anyway to fix it?
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
Stuck spacebar
« Reply #1 on: Thu, 05 January 2012, 21:33:27 »
Yes. I had the same problem. It happens when one of the stabilizers comes loose and jams itself in there. Just pull the spacebar off, pull out both stabilizers, apply an ample portion of glue (I just stuck them in an Elmers glue stick), reinsert them, let it dry (I stuck it in my computer case under my graphics card to let the low heat help out, since glue doesn't dry very quickly without air contact), and put it back on. Note that the longer part of the stabilizer will point the direction that the wire falls. Assuming all Blackwidows are the same, it should point towards the typist.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
