Author Topic: Making a Keyboard 10-keyless  (Read 3203 times)
Offline tethyrian
« on: Fri, 06 January 2012, 08:32:20 »
So I have a cheap rubber-dome dynex keyboard (Model No.: DX-WKBD) and I was wondering if (with some minor soldering) it was possible to make it a 10-keyless keyboard. Or possibly even cut it off at the F12/right-ctrl line. Trying to save a lot of space so just want to know if this is possible..
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Fri, 06 January 2012, 08:36:16 »
Generally the only way to do this with a rubber down is the fold the membrane and get it all to fit back in the case like that.  Then cut off the extra case section.
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #2 on: Fri, 06 January 2012, 08:36:53 »
It is completely possible, it isn't too hard... I don't have a link for you, but it is possible with a hacksaw and no soldering usually.
Offline tethyrian
« Reply #3 on: Fri, 06 January 2012, 08:41:25 »
Quote from: alaricljs;484573
I am assuming the ENTIRE membrane needs to be intact at all times than?
Offline alaricljs
« Reply #4 on: Fri, 06 January 2012, 08:44:35 »
This is usually the case.  The traces that go past the nav keys often turn around and come right back.  Often the controller is over in that section you want to get rid of as well.
Offline tethyrian
« Reply #5 on: Fri, 06 January 2012, 08:56:50 »
So, essentially, if I just cut the casing, the LEDs, and the PCB right where the 10-key is, but left the membrane intact, it "should" work?
Offline alaricljs
« Reply #6 on: Fri, 06 January 2012, 09:02:26 »
What PCB?  If it's a RD membrane, there should be no PCB except a small chunk to integrate the controller to the membrane and it's probably what the LEDs are attached to.  You'll need to keep that, otherwise it's not a keyboard any more.
