Author Topic: Portal Key Caps (not white)  (Read 5543 times)
Offline USAgent
« on: Fri, 06 January 2012, 09:46:45 »
Has anyone seen the Portal key caps in red or black? Do/can these exist :D
Filco MJ2 Ninja 104 |  Ducky Disco TKL
« Reply #1 on: Fri, 06 January 2012, 10:16:43 »
Hmm, in China, there is everything. Have you checked taobao?
I still have an unopened set of white that I'll figure out what to do with sometime.
Offline USAgent
« Reply #2 on: Fri, 06 January 2012, 10:21:26 »
Are you selling or just holding?
« Reply #3 on: Fri, 06 January 2012, 11:03:07 »
I'm still considering. If I don't come up with a way to use them, I'll sell at no profit, but organizing something that's fair and cheap is difficult, and I don't want to get into that right now.
There's a good chance I'll put them on a keyboard. Maybe I'll have one for each row on an ergodox or something.
Offline USAgent
« Reply #4 on: Fri, 06 January 2012, 11:25:33 »
I really only want the single man dropping into a portal for Esc, but I really want it white on red key or white on black key. I wouldn't mind having the keys for future keyboard purchases.
« Reply #5 on: Fri, 06 January 2012, 11:30:52 »
Remember: white on red or white on black can't bu dye-sublimated (like the white ones are) You'd need doubleshot (you only get one colour) or pad-printed (wear off) for that colour scheme.
Offline USAgent
« Reply #6 on: Fri, 06 January 2012, 11:45:29 »
:frown:
Offline bavman
« Reply #7 on: Fri, 06 January 2012, 11:47:23 »
These were made for a group buy here a couple months ago, so if you wanted another color scheme you'd have to get them custom made through SP.
Luckily for you, I only ever use 12 out of the 13 keys in the set because I have something else on escape, so I might be willing to let go of that one key you want.
