Author Topic: White Keycaps that fit a Leopold  (Read 7226 times)
Offline Trials
« on: Sun, 08 January 2012, 03:28:20 »
Anyone know where I could buy a set of Blank or Engraved White keycaps for a Leopold TenKeyless?
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1 on: Sun, 08 January 2012, 04:49:41 »
WASD keyboard could hook you up though if you want the color to match their light grey is close to the not very whit leopold color.
Offline Lamaboi
« Reply #2 on: Sun, 08 January 2012, 08:30:38 »
WASD spacebar fits Leo's now? I thought it was only Filco compatible.
« Last Edit: Sun, 08 January 2012, 08:33:34 by Lamaboi »
Offline Trials
« Reply #3 on: Sun, 08 January 2012, 14:09:58 »
Quote from: Lamaboi;485936
Yeah I thought the wasd spacebars didn't fit? can anyone clarify this.
« Reply #4 on: Sun, 08 January 2012, 15:48:34 »
Thats correct they dont fit. sorry im just so used modding the spacebars now that I forget about that and/or done see it as a problem any more. if you need me to mod the spacebar or other caps please let me know.
Offline Trials
« Reply #5 on: Sun, 08 January 2012, 17:18:03 »
Quote from: TheProfosist;486140
Yeah probably later on down the road just going to get the keyboard first for now.
Offline iwannaBfishfood
« Reply #6 on: Sun, 08 January 2012, 20:05:40 »
Anyone have any other alternatives to wasd? I'm looking for white key caps for my Tenkeyless as well.
« Reply #7 on: Sun, 08 January 2012, 20:09:57 »
Quote from: iwannaBfishfood;486263
not if you want blank you could get PBT engraved from qtan.
« Reply #8 on: Sun, 08 January 2012, 20:28:25 »
Quote from: TheProfosist;486272
I hate to sound like an idiot, but i'm new here. I couldn't find qtan from google. Do you mind giving me a link?
Offline bavman
« Reply #9 on: Sun, 08 January 2012, 20:37:47 »
Look under the marketplace part of the forum, he has his own subforum called elite esport gaming with a link to his website
« Reply #10 on: Sun, 08 January 2012, 20:41:39 »
Thank you very much for your help.
« Reply #11 on: Sun, 08 January 2012, 21:03:31 »
http://tinyurl.com/6k7mpzl you can even get side printed you can go to his store or just search PBT keycaps on ebay and look at the seller should be qtan if not ;look at another one there are only a couple sellers on ebay for PBT keys.
Offline Trials
« Reply #12 on: Sun, 08 January 2012, 22:27:19 »
Quote from: TheProfosist;486328
So are all of his Keys on his website and ebay store updated with the Leopold compatible spacebar? Just trying to make sure since his description doesn't say it anymore on the listings
« Reply #13 on: Sun, 08 January 2012, 23:35:03 »
Quote from: Trials;486399
The white ones should have it I every white set that I have gotten has had it black on the other hand has not.
