Author Topic: Filco Tenkyless Quality Questions?  (Read 2049 times)
Offline f0x
« on: Sun, 08 January 2012, 06:49:43 »
Hey,
in mid-december i got my first mechanical keyboard: A Filco Majestouch-2 Tenkeyless in german (ISO) Layout with MX Browns. So first of all, don't get me wrong, i think it's a great keyboard, but since i have it i noticed some small quality flaws that i wouldn't expect from a 140 Euro - Keyboard:
1. It wobbled after unpacking it. Luckily i could fix that by bending the case a little bit. Maybe it buckled because of temperature difference during shipping or so. No big deal.
2. The up-arrow key is misaligned, as mentioned in the "Filco Camo build quality prob?"-thread.
3. After only this short amount of time (less then a month), i hear a pretty strong and loud "spoing" sound from the springs in some switches, that i am sure should not be there. I don't know if this is normal, but it sure is pretty annoying.
4. The general audible feedback from the keys is very diverse. Again i don't know if this is normal, but it doesn't sound like a consistent unity.
Am i overly critical and all the things are completly normal, or did i just have some bad luck and got a less then optimal model?
Offline Lolcakes
« Reply #1 on: Sun, 08 January 2012, 09:44:15 »
I think thats rather normal for filcos. I used to have one, but i switched to a leopold and I kinda find the leopold to be better. My filco used to wobble as well bu my desk was wasnt perfectly flat. However my leopold, doesnt (I guess due to the wider ribber feet)
Offline Ciardhubh
« Reply #2 on: Sun, 08 January 2012, 10:34:45 »
Quote from: ripster;485948
The McRip Effect.
Out of curiosity: what would be the opposite of the McRip Effect? Say, some kind of "people buy into a hyped brand at a premium price, so there cannot be any flaws; and even if there were, they aren't really worth mentioning, otherwise said buyers would have to admit they start getting second thoughts and nobody likes to admit their choice might not be the bee's knees after all"-phenomenon? The PBIAHBAAPPSTCBAFAEITWTARWMOSBWHTATSGSTANLTATCMNBTBKAA-effects sounds a tad unwieldy.
Offline nhwhaup
« Reply #3 on: Sun, 08 January 2012, 11:07:04 »
I don't agree with rationalizing that it's okay for an expensive product or any product I purchase to have quality flaws, poor workmanship or sub-par materials.  However, that being said, it's pretty near impossible at least in my world to find a perfect product.
I've been fortunate that my TKL Filco with reds has been top notch quality with absolutely no issues and my arrow keys are all aligned and evenly spaced.  I have two Realforce boards and it does really bug me that the spacebar is ABS.  That being said, I like the rest of the board so well and the feel of the keys that I will put up with not having a better material spacebar.  And I have a Poker with reds that I would like so much better if it had designated arrow keys but it doesn't - the Nippoo does but doesn't work with Macs and I have both PC's and Macs.  So for now the Poker is the best option for me when traveling to use with my iPad.
So I think all in all consumers will shop for what works best for their needs, budget, preferences and quality.  I know a lot of folks that would never be as picky with things as I am but I do expect good quality or will return an item.  If my Filco had the issues as the one mentioned in this thread and they bothered me, then I would send it back.  If they bug you now, they will continue to bug you.
It's all a matter of preference.  After all this being said - if a consumer accepts "good enough" it will be good enough and the producer won't innovate for an improved product.
« Last Edit: Sun, 08 January 2012, 11:09:40 by nhwhaup »
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline eth0s
  • Peace & Love
« Reply #4 on: Sun, 08 January 2012, 15:02:11 »
Quote from: f0x;485910
Well first of all, this may simply be a case of Buyer's Remorse (which is a form of post-decision dissonance).  However, I suspect that what is happening here is a mixture of a little Buyer's Remorse, a little shipping damage, and a heavy dose of "German culture shock at low quality control from Asian manufacturers" which is a culture-specific phenomenon that is not described by American Psychology (the DSM-IV is notoriously bad when it comes to the diagnosis of non-English speaking people).  The OP is German, and German people expect everything to be made in the way a German person would make it, i.e., it should be made with exceptional attention to detail and high quality control.  However, manufacturiong in China (or Taiwan), is entirely different.  German consumers are willing sacrifice price to improve quality, whereas the Asians will sacrifice quality to keep the price (are more accurately, the cost of manufacturing) low.  Here we have a German person who thinks he is spending more money to get higher quality (as is customary in Germany).  In America, we have learned that such a tradeoff does not always exist, and that higher priced goods are not necessarily of super high quality.  All that you can really expect from a Filco is that it is better than a rubber dome keyboard.  With that preface, I will address the specifically enumerated concerns of the OP:
1.  Wobbling: your keyboard got bent during shipping.  Why?  Poor packaging.  (Saves money.)  Fix?  Try GENTLY bending the metal plate back into relative flatness with your hands.  If it is irreparably bent, I would say this is good cause for an RMA.  Filco is to blame for inadequate packaging used for shipping, especially since they charge the customer for shipping and handling.  (Notice to Filco Distributors:  Shipping and Handling are NOT a valid means to generate extra profits.)
2.  Mis-aligned Arrow Key:  Manufacturing defect.  Everything that is manufactured anywhere in the universe will have some variability.  No two items will ever be exactly the same.  This is how the laws of probability work in our universe.  However, the physical difference between each manufactured item will most likely be very slight (within two standard deviations, or "two sigma" as it is commonly known), but on very rare occasions, you will get an extreme outlier (beyond six sigma), which might be what you got.  Fix?  You can buy a set of new arrow keycaps over the internet -- you can get them for $4 or less, and you can get them in a rainbow of colors.
3 & 4.  "Spoing":  this is an entirely subjective complaint about the sound of the keyboard.  However, I don't think anybody should minimize it, or doubt that the OP really hears it.  I believe he hears it, and I believe it bothers him.  On the other hand, I am not willing to say that it is a manufacturing defect.  What is causing the spoing sound?  I honestly don't know.  I also don't know if the spoing sound is simply the normal sound of a Filco keyboard.  A Filco will make a particular sound when the keys are pressed, and that sound has a vaguely metallic resonance or tone, due to the metal plate inside the keyboard.  This is entirely normal.  So the question becomes, is the OP's spoing sound unusually bad?  I have no idea, and this gets into the whole Filco ping issue, which was the subject of so much sturm und drang, and so little beneficial discussion.  All I can say is that if it really bothers you, you may have to try to return the board with the explanation that the product is not suitable to you, even though it appears to be working correctly.
Well in conclusion, I would say that if the keyboard is really bent then you should RMA it, as that should not happen.  Second, maybe the bent metal plate inside the keyboard is producing an unusual sound, or it is making some keys sound like a "spoing".  Third, when looking at the gestalt, i.e., given the bent keyboard, and the misaligned keys, and the "spoing", maybe you have sufficient grounds for an RMA.  I have two Filco's and I am extremely happy with them, and I would like to see you have the same satisfaction with your keyboard, and I'm sure Filco would too.
« Last Edit: Sun, 08 January 2012, 15:07:25 by eth0s »
Offline f0x
« Reply #5 on: Sun, 08 January 2012, 19:46:00 »
Wowowow, seems like you've gotten me kind of wrong here. As i said, its my first mechanical keyboard, all i hoped to read was:
"don't worry, its all common, your keyboard is fine."
I fixed the wobbling, its fine now.
I did not know, that the whole "pinging"-issue was a big topic. Actually i just have it on my "s"-key and i can totally live with it.
The rest was just minor things i observed by testing the keyboard out, they don't bug me at all.
Definetly no case of buyers remorse here. I think the keyboard is great. And no, also nothing to do with my german cultural background :)
Offline pitashen
« Reply #6 on: Sun, 08 January 2012, 19:51:03 »
The revenge of the ping!!!!!!!!!!!
