Author Topic: How to buy individual switches? Also can you put different switches on a kbc poker?  (Read 2589 times)
Offline Riley
I've had 3 keyboards so far, Filco 10 keyless with blues, 1988 IBM Model M, and my one I'm currently typing on, KBC Poker with blacks. I sold the Filco though. :p
I've liked all of these types of switches so far, but I would like to try out different kinds, I figured the easiest way would be to put another type of switch on my KBC Poker. I'm looking for 1 red, brown, a clear. If anyone knows where I could get these in the US and if I can even swap them on KBC Poker, that would be appreciated.
Offline Human
Quote from: Riley;486049
For POKER(PCB mounted), swapping switch mean you find a thing, poke out the top case of the keyswitches and then swap the stem or spring, then put the cap on. If you are hardworking, you can also desolder the switch off and swap the whole switch.
Though, do note that the PCB mounted cherry switch is not completely the same with those plate mounted board. PCB mounted had and require the extra 2 plastic pin for proper/firmer grip onto the board. If you are only swapping the stem off, it will be perfectly fine.
Offline keyboardlover
Yes. Click my sig for details.
Offline Riley
All the websites that I went to didn't really help, they just give you model numbers. HOW AM I SUPPOSED TO KNOW WHAT COLOR EACH MODEL NUMBER IS? Even if you try to Google that model number, that doesn't help, it just gives you several different colors  all at the same time.
Offline o2dazone
http://www.mouser.com/Mobile/Electromechanical/Switches/Keylock-Switches/_/N-5g2u?N-5g2u&Keyword=cherry+mx&FS=Tru. Here's some. I believe the descriptions should let you which ones they are. Although the wiki here on the forum should give you exact model numbers. This is the most expensive way of getting switches. Most people just but beat up or defective "donor boards" and harvest switched from there.
Offline False_Dmitry_II
TBH, you could do that, but it seems more expensive (or at the very least far too close to that considering the time you'd have to use doing it) than just buying other boards with those types.
I can see doing that if you're trying to create something that doesn't exist, like ergo clears, but just switching between standard things seems odd to me.
Offline pitashen
Quote from: False_Dmitry_II;486398
+1
Not quite worth it. If you check the unit price they are at digikey, you should realized that replacing the whole set of switches on your keyboard will cost just about as much as getting another board. Not to mention the labor time you will be putting into.
Offline squarebox
  • In Omnia Paratus
[video=youtube;bLBXxzmuA_Q]http://www.youtube.com/watch?v=bLBXxzmuA_Q[/video]
- #2 KE
« Last Edit: Sun, 08 January 2012, 23:54:17 by squarebox »
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline TheProfosist
  • Custom Layouts Only!
Just buy from wasd and if u ever want a board converted let me know.
Offline Riley
I'm not looking to convert a board, atleast not yet. :p
I'm just looking for one of every switch to try out.
Offline IvanIvanovich
  • Mr. Silk Underwear
Well you really only need stems and spring not whole switch. It's really easy to pop them and swap, like in the video squarebox posted. One clear stem and one brown stem and spring. Red is same as black stem and brown spring, and black and clear use same spring I think. If I had any extra from my modding I would let you have them, but I only have some linear greys left over.
I understand that but it may just be easier to pick up the whole switch depending
« Last Edit: Tue, 10 January 2012, 01:52:22 by TheProfosist »
Actually clear uses one that seems much stronger than even black.
Offline REVENGE
Currently running Ghetto Reds in the alpha section of my Poker, Blues in the rest.
