Author Topic: Is IBM KB-6326 a mechanical clicky keyboard?  (Read 10606 times)
Offline cheewie
« on: Tue, 10 January 2012, 13:33:59 »
So, Ive got a chance to buy a IBM KB-6326. Thing is I cant find much info about it. Do you guys know if its a clicky one?
Offline Lmnr
  • The Jack Of All Trades
    • W.W.C.
« Reply #1 on: Tue, 10 January 2012, 13:38:58 »
Most likely not from the price suggestion states 5$ but at least cosidered high quality rubber dome. Same as my kb 8923
Peripherals:
Realforce 87uw with grey caps,Ducky YOTR Blues,Realforce 104ug Hipro,Zowie Am FG,WMO 1.1a,Sidewinder X3
Offline Pylon
« Reply #2 on: Tue, 10 January 2012, 18:33:16 »
It's guaranteed to be a rubber dome.
Offline EverythingIBM
« Reply #3 on: Tue, 10 January 2012, 18:37:08 »
I have a couple of them, they ARE rubber domes.
They were manufactured by chicony for IBM.
Mind you, they're probably the best quality rubber dome you're ever going to get. But I wouldn't spend money on one.
