Author Topic: Not sure if McRip Effect.... (HHKB Pro 2)  (Read 1737 times)
Offline cheebs
« on: Tue, 10 January 2012, 20:13:10 »
Well I finally got the HHKB Pro 2 under my paws.
Needless to say it feels awesome, and the media / device controls are a nice addition to such a small layout.
One thing I noticed immediately however is the lack of grip on the bottom right rubber foot (the one underneath the HHKB logo).  I'm able to scoot it with very light pressure.  The left side is very solid.  This isn't something I'm willing to send the keyboard back for, but I was just wondering if it's a known / common issue, and what some of you with the same issue have done to fix it.
Offline chel-
« Reply #1 on: Wed, 11 January 2012, 14:15:54 »
The sliding is a known issue. You can just buy some stick on rubber pads and put them on or you could just try putting them on a 2nd mousepad. I just learned to live with it personally.
