Author Topic: Rubberish Keyboard Liner  (Read 3330 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Wed, 11 January 2012, 12:37:21 »
Anyone knows where I can buy this liner thinge for keyboard bottom?  Thanks.
Offline litster
« Reply #1 on: Wed, 11 January 2012, 12:39:35 »
Thanks ripster!  I am so ignorant with household items...
Offline jkercado
  • Green XM clickclacker
« Reply #2 on: Wed, 11 January 2012, 12:41:07 »
What's your plan with that? Put it underneath the keys to dampen the bottom-out noise? Seems like a good idea, and better than foam...
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
Offline litster
« Reply #3 on: Wed, 11 January 2012, 12:51:16 »
I want to use it to line my acrylic keyboard cases.
Offline mmmty
  • bang! bang!
« Reply #4 on: Wed, 11 January 2012, 13:06:50 »
You have acrylic keyboard cases?? :eek:
Keyboardless
« Reply #6 on: Wed, 11 January 2012, 14:18:31 »
That type of drawer liner works great.
I have used it inside the keyboard for sound deadening, and also under the keyboard on the desk to keep it from sliding around.
Solves those "warped" keyboard problems, too, if they aren't more than a couple of mm out of square.
- Oliver Willis 2026-08-01
Offline mmmty
  • bang! bang!
« Reply #7 on: Wed, 11 January 2012, 15:51:47 »
Very nice!! Put my name on group buy list in the other thread.
Keyboardless
Offline litster
« Reply #8 on: Wed, 11 January 2012, 15:56:34 »
Quote from: fohat.digs;488124
For warped keyboard cases, just hold your keyboard on both sides with your hands, then twist it up or down depends on which way it warps, and it will be flat again.
Quote from: mmmty;488180
I got you.  Not sure if it will happen though.  I think most people will find it too expensive and not worth it.
Offline enoy21
« Reply #9 on: Wed, 11 January 2012, 16:01:56 »
I use this stuff right now under my WASD to dampen the vibrations hitting the space bar on an aluminum desk.   The board itself doesn't ping but the desk sure as hell does !  It's also a great thing to use with any board that doesn't have the rubber tipped feet as it's super slip resistant
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline TheProfosist
  • Custom Layouts Only!
« Reply #10 on: Sat, 14 January 2012, 02:12:50 »
I have this inside my wasd for sound dampening along with some lead to give it some more heft. I did the same mod with a fair bit less lead on 3 rosewills. And have just put the cabnet liner in the SS7G that i repaired.  I quites bottoming out quite bit and get rid of the ping if there is/was any.
Offline Reptile
« Reply #11 on: Sat, 14 January 2012, 03:08:10 »
I actually have this stuff under my monitor stand and my mouse pad. I am pretty sure I got it from target.
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
