Author Topic: keyboards with Caplock/Ctrl dip switches  (Read 4664 times)
Offline FinancialWar
« on: Fri, 13 January 2012, 01:55:59 »
So far I know (due to my limited knowledge) there are three keyboards on the market that have caplock<>Ctrl dip switches.
What other keyboards on the market that have dip switches for CapLock<>Ctrl swapping do you know and I will put in the list.
1. Topre 87U
2. KBC Poker
3. TBtalking Race 75%.
4. Ducky 9008 Shine
« Last Edit: Mon, 16 January 2012, 18:12:32 by FinancialWar »
Offline laffindude
« Reply #1 on: Fri, 13 January 2012, 01:58:27 »
Only other one I know is Poker (and pure if you want to count that).
« Reply #2 on: Fri, 13 January 2012, 02:13:58 »
indeed the Poker and it is the cheapest one too. Thanks for that.
Offline gilgam
« Reply #3 on: Fri, 13 January 2012, 05:10:52 »
Quote from: dvorak;489320
2. Happy Hacking Keyboard Pro 2
The hhkbp pro 2 only has the ctrl key on the right place. I didn't knew it was possible to dip switch it as a capslock
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
woody
  •  Guest
« Reply #4 on: Fri, 13 January 2012, 08:53:52 »
Quote from: gilgam;489380
It's actually on the left.
No, you can't. CapsLock is Fn+TAB, except if you're in HHKB mode - then there is none. HHKB mode is weird.
« Reply #5 on: Fri, 13 January 2012, 10:56:27 »
Thanks. I learnt something today about the HHKP2
« Reply #6 on: Mon, 16 January 2012, 10:05:55 »
any other keyboards?
Offline theOwlol
« Reply #7 on: Mon, 16 January 2012, 10:15:13 »
I think the Ducky Shining got it.
fossala
  •  Guest
« Reply #8 on: Mon, 16 January 2012, 10:21:11 »
Any programable board like the Kinesis advantage and if they ever keep there promis and release the software TrulyErgonomic should be.
Also northgate omnikey does on some models.
Offline Adelhyde
« Reply #9 on: Mon, 16 January 2012, 16:27:05 »
Northgate Omnikey boards and Avant Stellar boards, their rebranded successors, let you move Caps Lock to Alt, Alt to Ctrl and Ctrl to Caps Lock. But it depends on what you mean by "on the market," they're not being made any more.
Offline gig
« Reply #10 on: Mon, 16 January 2012, 16:57:05 »
Noppoo choc mini's have a switch lock button to change the ctrl and caps lock positions.
Offline oneproduct
  • @Ubisoft
« Reply #11 on: Mon, 16 January 2012, 16:58:06 »
On the Noppoo Choc Mini you can switch them, but not as a dip switch, it's called "switch lock" and I imagine you have to toggle it on each time you turn on your computer. My brother is using one, I'll try to double check that.
Layout: Colemak
Offline gig
« Reply #12 on: Mon, 16 January 2012, 17:04:20 »
Yes, its must be switched on every time you turn on the computer.
« Reply #13 on: Mon, 16 January 2012, 18:12:56 »
sorry must have a physical switch to qualify.
« Reply #14 on: Mon, 16 January 2012, 21:19:19 »
Ducky Shine is awesome, I think I might get one.
Any other full size keyboard that have the dip switch?
Offline absfac
Re: keyboards with Caplock/Ctrl dip switches
« Reply #15 on: Thu, 10 April 2014, 20:32:53 »
I was doing some research today about this subject, so I'm resurrecting this old thread to keep it authoritative...
The Shine 9087 seems to also have a DIP switch:
http://www.duckychannel.com.tw/en/DK9087_shine2.html
I think possibly Ducky's G2 series 9008 and 9087 as well? Info pages mention DIP switches. Not documented what they do, but given the lineage, it's probably the same as the Shine series with the same model numbers.
http://www.duckychannel.com.tw/en/DK9008_G2Pro.html
http://www.duckychannel.com.tw/en/DK9087_G2pro.html
Of course the CODE keyboard has this feature. I'm sure many of you know that already as CODE has gotten plenty of press.
http://codekeyboards.com/
It looks to me like pretty much all WASD V2s have it. Makes sense. CODE is pretty much a fancified rebranded WASD V2.
http://www.wasdkeyboards.com/media/v2-user-guide.pdf
The Majestouch Minila, discussed in this GH thread, has DIPs:
http://geekhack.org/index.php?topic=40018.0
The Northgate OmniKey is not "on the market" (except maybe used) but apparently its DIP switches supported this swap.
http://deskthority.net/wiki/Northgate_OmniKey_101
Also, not entirely relevant but slightly related the so-called "truly ergonomic" keyboard has a ridiculous array of DIP switches some of which affect ctrl although none of the configurations map it to the position left of the "A" key. lol.
https://trulyergonomic.com/store/installation-and-quick-start-guide--truly-ergonomic-mechanical-keyboard
Offline Bucake
« Reply #16 on: Thu, 10 April 2014, 20:39:28 »
pure pro switches the left Fn key (which is next to left ctrl) with caps lock.
« Last Edit: Thu, 10 April 2014, 20:42:50 by Bucake »
Offline thestage
« Reply #17 on: Fri, 11 April 2014, 00:57:37 »
add the Leopold FC660c to the list.  the 660m probably has it too, but I don't actually know.
Offline piglickjf
« Reply #18 on: Fri, 11 April 2014, 15:15:53 »
Keycool 108 doesn't have a dip switch, but one of the 4 "extra" keys on the top right swaps Ctrl/Capslock.
PigLick
