Author Topic: Not sure what kind of switches are in my rather old keyboard.  (Read 2736 times)
Offline kheath812
« on: Mon, 16 January 2012, 04:58:35 »
I know it's a stretch but i'm wondering if I cant get some help figuring out what kind of switches my keyboard has. I'm looking to buy a new keyboard and i'd like the feel of the keypress and the sound to remain as similar as possible, but I cannot find any specs on my keyboard because i'm pretty sure it's discontinued.
Compaq PS/2 Keyboard
Model 5107
P/N 5187-2154
i.imgur.com / I73B6.jpg   <- picture of the keyboard for reference.
I've looked at the differences between switch types but it's a little hard to figure out which is similar to mine when this is pretty much the only keyboard i've ever used so i dont have a feel for comparison. Is there an easy way to figure out what kind of switches it has? like taking a key off and it being a certain color underneath? Forgive my retardation, I'm lost and confused. :(
-I took a keycap off and there doesnt seem to be any kind of switch or spring or anything. Deep inside the square hole that the keycap sticks on there seems to be a little white rubbery circle. Any idea what that is?
Offline cactux
  • Topre Knight
« Reply #1 on: Mon, 16 January 2012, 05:03:36 »
If you have the keyboard, remove one of the keycaps and take a picture ( remove any keycap from a-z)
[FS]☠ The temple lol ->HERE<-
Offline Tony
« Reply #2 on: Mon, 16 January 2012, 06:57:15 »
No + sign? So it's a rubber dome I guess.
For easy inspection, get several keycaps off and take a closeup picture.
Offline flyball
« Reply #3 on: Mon, 16 January 2012, 08:24:04 »
Quote from: kheath812;491541
sounds like a dome.
Quote from: Tony;491575
incorrect
[SIGPIC][/SIGPIC]
Offline cactux
  • Topre Knight
« Reply #4 on: Mon, 16 January 2012, 14:17:18 »
Dome
Offline kheath812
« Reply #5 on: Mon, 16 January 2012, 14:41:35 »
sorry for the slow response, i guess you guys figured it out. but here are the pictures anyway:
i.imgur.com /SMjIu.jpg
i.imgur.com /uyRo3.jpg
are keyboards with "dome switches" even made anymore? modern keyboards anyway? and if not is there any type of cherry switch which feels the same/similar?
Offline cactux
  • Topre Knight
« Reply #6 on: Mon, 16 January 2012, 14:50:58 »
^ most of the keyboards out there uses ruber domes.
Offline kheath812
« Reply #7 on: Mon, 16 January 2012, 14:54:14 »
thanks for the response :)
