Author Topic: 1986 Model F on Ebay - XT or AT?  (Read 2190 times)
Offline ed_avis
« on: Tue, 17 January 2012, 08:34:23 »
Ebay item 120838484500 is a 1986 Model F keyboard.  It has a round DIN connector so I assume it's not a terminal keyboard.  The layout has gaps and function keys along the top, so does that mean this must be a PC-AT keyboard?  Or were some made with the larger layout but still XT-style electronics?
« Reply #1 on: Tue, 17 January 2012, 08:54:01 »
That is a terminal keyboard. Looks like a nice one. Note the 240 degree plug instead of 180 degrees.
Way out of my price range, however, but I have 3 almost exactly like it.
If Soarer's conversion works, it could make a really nice board, I would recommend it if you can afford it.
And if you have a couple of hours, and the inclination to engage in a project like this.
« Last Edit: Tue, 17 January 2012, 12:12:32 by fohat.digs »
- Plato
Offline ed_avis
« Reply #2 on: Tue, 17 January 2012, 08:56:07 »
How do you tell it is a terminal keyboard?  Simply because it has 122 keys?
« Reply #3 on: Tue, 17 January 2012, 10:35:27 »
As far as I know, all 122-key boards are for terminals, whether Model M or F.
Also, the 240 degree DIN plug is another giveaway. Terminals can have any of several different connectors.
And all mine are 6110347, I think that whole number line is for terminals.
Has anybody out there seen a 122-key that is not for a terminal?
« Last Edit: Tue, 17 January 2012, 12:13:05 by fohat.digs »
- Plato
Offline Luhmaniac
« Reply #4 on: Tue, 17 January 2012, 10:58:02 »
Geekhack member JohnElliott gives a description of this board on his website.
I'm not sure if it will work with Soarer's adapter. The board uses Scancode Set 3 but doesn't send break codes.
Offline DaemonRaccoon
« Reply #5 on: Tue, 17 January 2012, 12:18:24 »
Soarer's adapter will work.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline ed_avis
« Reply #6 on: Tue, 17 January 2012, 12:32:27 »
Thanks.  I'll stay on the lookout for PC-AT keyboards.
Offline bootstrap
    • epiguru.com - My Personal Website
« Reply #7 on: Tue, 17 January 2012, 12:43:33 »
Quote from: ed_avis;492604
This is a Model F PC/AT on auction: http://goo.gl/vqODs :smile:
The Best WordPress Theme Ever | Kinesis Contoured Model 100 | IBM Model F 1387033 "Space Unsaver" | CH Products DT225 Trackball x 2
Offline ed_avis
« Reply #8 on: Wed, 18 January 2012, 01:23:50 »
So the auction description of '5150/5160' is not correct.  (5150 is the IBM PC, and 5160 is the PC-XT.)  It certainly looks more like an AT keyboard than an older one, but perhaps it is one with AT layout but older electronics?
Offline bootstrap
« Reply #9 on: Wed, 18 January 2012, 03:17:02 »
That keyboard will work with any AT to PS/2 converter (even the cheap varieties) with or without a PS/2 to USB adapter (you have to be more selective about the latter because some won't work). I've had success with the Ziotek one.
Some sellers have only a scant idea of what they are selling. Unlike most Model Ms, the Model F PC/AT doesn't have something on its case to identify it as a "Model F." That spells opportunity. :biggrin:
« Reply #10 on: Wed, 18 January 2012, 09:18:16 »
Quote from: bootstrap;493239
Like this "IBM Model M keyboard":
http://www.ebay.com/itm/IBM-Model-M-Keyboard-/190628486750?pt=LH_DefaultDomain_0&hash=item2c6257de5e
Looks like an XT model F to me....
Offline bootstrap
« Reply #11 on: Wed, 18 January 2012, 20:01:23 »
To be clear, I was referring to this keyboard: http://goo.gl/vqODs
« Reply #12 on: Wed, 18 January 2012, 20:06:56 »
Late last summer a few of us were desperate for Model F ATs and drove the price well over $100 for a couple of months.
It looks like these are trading at more reasonable prices now, at least < $100
- Plato
