Author Topic: My Mech KB is causing my computer to not boot.  (Read 2004 times)
Offline killeraxemannic
« on: Tue, 17 January 2012, 14:20:51 »
I have a Razer Black Widow keyboard, and if it is plugged in my computer won't boot past the bios screen. It will get to the bios splash screen and stop. If I unplug it all is well and it will boot up. The keyboard works just fine if I plug it in after windows is booted. It also boots fine with another USB keyboard plugged in.
Any ideas?
Offline stingrae
« Reply #1 on: Tue, 17 January 2012, 15:05:30 »
I am guessing you have tried other USB ports?
It may be down to BIOS settings perhaps make sure support for legacy/all USB devices is enabled or even try disabled (although that might need a ps/2 keyboard to get you back into bios). I'm sure i've had a simmilar problem in the past with a mouse or something but I can't quite remember.
Filco Ninja Tenkeyless  -Noppoo Choc MiniCm Storm Quickfire Rapid
Offline weenis
« Reply #2 on: Tue, 17 January 2012, 15:07:46 »
Make sure your BIOS is up to date.
Dell AT101W | Unicomp Spacesaver PC | IBM SpaceSaver Keyboard | IBM Black Label M | KBT Oni Brown | Leopold Otaku Brown | Noppoo Choc Mini Brown | IKBC F104 Brown
Offline stingrae
« Reply #3 on: Tue, 17 January 2012, 15:11:59 »
Just realised the blackwidow may have a firmware update: http://www.razersupport.com/index.php?_m=downloads&_a=view&parentcategoryid=189 which may or may not help at all. I'd try that before flashing a working BIOS version.
Offline naranja
« Reply #4 on: Tue, 17 January 2012, 17:29:20 »
Might have to do with the boot order in your bios. Just make sure it reads from the hdd before usbs.
Offline erw
« Reply #5 on: Tue, 17 January 2012, 17:49:32 »
If the above doesn't help, try it with another computer to find out if it is your BIOS settings or the board itself.
Kinesis Advantage LF (MX Red), Kinesis Advantage (MX Brown), Ergodox (MX Red), Colemak
Offline laffindude
« Reply #6 on: Tue, 17 January 2012, 18:48:17 »
Try plugging in a mouse in the USB port on the right
