Author Topic: It's posible to print your own flexible keyboard matrix?  (Read 2498 times)
Offline LukStarkiller
« on: Fri, 20 January 2012, 11:38:37 »
I'm trying to build an hybrid from two keyboards (an ibm M and a G15), but I need to make a new matrix. Designing the matrix it isn't dificult, But then I don't know how to "print" the matrix.
I found several companies that make flexible circuitry and some of them exactly like this, but all of them in large quantities.
Looking for DIY, I found in Instructables a guide to make flexible circuitry on copper. But it seems to bend and deform too easily, unlike a printed matrix.
Anyone know a company that does this in little quantities, or another method to make one?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Fri, 20 January 2012, 11:48:49 »
Some people have had success with loading piezoelectric inkjet printers with conductive ink for doing circuits on mylar.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #2 on: Fri, 20 January 2012, 12:23:31 »
woah, that's awesome. if you try this let us know how it goes
« Reply #3 on: Fri, 20 January 2012, 12:29:31 »
Quote from: lysol;494937
Do you know what type of conductive ink, because the one I found costs 600€ a can. ^^U
Quote from: mkawa;494964
Don't worry about that, if I can make a matrix I'll put on the forums the results ^^
« Reply #4 on: Fri, 20 January 2012, 14:01:00 »
Not sure, I can't find it either since I don't know brand names. I just remembered reading an article on it awhile back. Sorry I can't be more helpful.
Offline mkawa
« Reply #5 on: Fri, 20 January 2012, 14:11:20 »
could you bond the copper foil onto a polymer film base? that might help it keep shape
eta: it looks like the pyralux already has a kapton base but it's very thin.. could it be epoxied down to mylar or nylon after printing?
« Last Edit: Fri, 20 January 2012, 14:13:46 by mkawa »
