Author Topic: Question regarding Cherry G-80 and G-81 keyboards  (Read 1668 times)
Offline bazemk1979
« on: Sat, 21 January 2012, 11:40:42 »
I have been looking at this 2 models of Cherry corp, mostly looking on ebay for those that they are without the card reader thingy, not sure if all of this models are mechanical... any help someone to tell me which are mechanical and which are rubber domes?
Offline Linkas
« Reply #1 on: Sat, 21 January 2012, 11:50:46 »
G80 has MX mechanical switches. G81 has MY switches.
Check this out http://geekhack.org/showwiki.php?title=Cherry+Corporation+Switch+Wiki
G80-3000
Online Findecanor
« Reply #2 on: Sat, 21 January 2012, 12:43:32 »
Once you have read about the various switches, you can read the Dating Cherry keyboards wiki article on how to decipher the model number and find out which MX switch the G80 keyboard has. Note that there have been keyboards that have not followed that numbering.
Not many members on this board like the MY switches in the G81 keyboards, and I find it unlikely that you will either.
Personally, I think that you should go with the G80 keyboard.
« Last Edit: Sat, 21 January 2012, 12:50:44 by Findecanor »
Offline bazemk1979
« Reply #3 on: Sat, 21 January 2012, 18:25:31 »
thanks for the info guys,so the MY are mechanical but not the real deal,they dont feel same as the MX ones although I believe they are rated at 50M clicks right.Nice to know I will look into it later about the markings on the model numbers to figure out the switch type,keycaps plastic and type of engraving is done. I will keep to the G80 models then,thank you!!!!!!!!!!!
