Author Topic: Monterey FKD46AK9AX - what is this?  (Read 2171 times)
Offline stefanjhill
« on: Wed, 25 January 2012, 20:59:07 »
Hi,
First post, I tried to do the search thing but have come up blank.  I see on the wiki there is reference to a;
Monterey Rubber Dome
Monterey FKD46AK208
Does anyone have any information on my FKD46AK9AX keyboard?  It has a XT <--> AT switch on the bottom, and has a serial number of 9013939.  When you remove a key there is a light yellow cross-patterned post the the key sits on.
Any help appreciated, especially if I can use a 5 pin DIN to PS/2 adapter and use this keyboard on a modern computer.  If so then would I be better off sticking with my SGI AT101 or changing to this (even more retro looking) Monterey keyboard.
Many thanks in advance,
   Stefan.
Offline terrycherry
Re: Monterey FKD46AK9AX - what is this?
« Reply #1 on: Thu, 07 December 2017, 03:26:45 »
Show me some photo first. It can use with the AT-PS/2 converter.
Your keyboard are very rare. It should be the Jameco logo keyboard made be Monterey in 1986.
I hope it should be well documented if you can help.
« Reply #2 on: Thu, 07 December 2017, 08:04:50 »
 holy necro post batman.....
