Author Topic: Wey EK2000  (Read 2860 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
Wey EK2000
« on: Wed, 25 January 2012, 23:34:00 »
Got this a while back.  mainly double shot keycaps in unique black on white-ish color, and the color keys are pad-printed, but the best pad-printed keys you will ever find.  However I can't get the keyboard to work with my computers, as a "connector box" is required.  It is basically a keyboard used with a dedicated KVM box, mainly used for stock trading.
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
Wey EK2000
« Reply #1 on: Wed, 25 January 2012, 23:52:06 »
Pull a keycap!
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline litster
Wey EK2000
« Reply #2 on: Wed, 25 January 2012, 23:58:19 »
I did.  It is MX Clear.
Offline IvanIvanovich
  • Mr. Silk Underwear
Wey EK2000
« Reply #3 on: Thu, 26 January 2012, 08:29:14 »
Pretty sure that big whatever its called metal connector in the center is the IN, and carries all the lines for ps/2, usb, audio... a matter of figuring out which pin is what and making a break out cable, or replace that big ugly mudsucking connector with usb in, ps/2 in, audio in.
Offline digitalleftovers
Wey EK2000
« Reply #4 on: Thu, 26 January 2012, 11:41:28 »
I hope 'corp del' deletes corporations.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline Glukos
Wey EK2000
« Reply #5 on: Thu, 26 January 2012, 12:00:20 »
MUNI-MUNI-MUNI :music:
Offline OPR8R
Wey EK2000
« Reply #6 on: Thu, 26 January 2012, 12:13:01 »
Quote from: digitalleftovers;499635
I'm in for a group buy if it does!
Offline litster
Wey EK2000
« Reply #7 on: Thu, 26 January 2012, 12:26:19 »
Quote from: lysol;499491
It does come with a cable for that big wide plug.  And suggestion on how to find the 5 PS/2 pinouts?
Wey EK2000
« Reply #8 on: Thu, 26 January 2012, 12:32:48 »
Crack it open, and you should at least be able to find the primary connection to the keyboard controller by following traces. That should at least get a start. Figuring out which is which is the more annoying part, unless they were nice enough to label the trace.
« Last Edit: Thu, 26 January 2012, 12:34:55 by lysol »
Offline litster
Wey EK2000
« Reply #9 on: Fri, 27 January 2012, 00:11:03 »
I opened up the case.  And it is actually more complicated than regular keyboards.  There are 2 PCBs.  One at the bottom with all the chips and connectors to communicate with the "connector box".  There are 2 8-pin headers on it (see highlight in pictures).  The keyboard PCB has 2 8-pin holes to connect with the 2 pin headers on the main PCB.  At first I thought, great!  Those must be the pins for the matrix.  But no.  It has over 130 keys.  8x8 is not enough.  Then I saw there are more tiny chips on the keyboard PCB.  I think the chips convert the matrix into a different protocol to the main board and then communicate to the connector box.
« Last Edit: Fri, 27 January 2012, 11:04:23 by litster »
Wey EK2000
« Reply #10 on: Fri, 27 January 2012, 10:41:50 »
Wow, that's pretty wacky. I wasn't expecting it to be quite that complicated. In my opinion, it's either museum piece (until you can locate an interface module), or harvesting time.
