Author Topic: Best Competitive SC2 Board  (Read 16206 times)
Offline Shirukii
« Reply #50 on: Fri, 27 January 2012, 09:18:20 »
Flash definitely still uses the dt35, the guy is borderline OCD with his setup, measuring distance and angles between his monitor and keyboard, taping down his mousepad, etc. He'll likely use the same gear until he dies.
CM Storm QuickFire Rapid | Ducky DK9008 | IBM Model M
Offline mTwTT1
« Reply #51 on: Fri, 27 January 2012, 10:07:49 »
i measure my keyboard tilt angle too : D
@cherryblossom99 i think ur thinking about july
Offline tsangan
  • 1000/600
« Reply #52 on: Fri, 27 January 2012, 10:10:41 »
Quote from: Gin;500280
TT1, I think it might be the keycaps making the switches feel different. It's the same case with my Filcos and Leopolds. Although I don't think there's a variation in required forces.
They do feel different, Filco's black is really really stiff compared to others
Keyboardless
Offline mTwTT1
« Reply #53 on: Fri, 27 January 2012, 10:46:20 »
are clear switches lighter than black switches? im looking for a switch that has an actuation force in between reds & blacks
Offline Gin
« Reply #54 on: Fri, 27 January 2012, 10:51:43 »
Clear switches feel like blue switches, without the click sound. But they are a bit heavier and I find it hard to play for an extended span of time without noticing the fatigue on my fingers.
You might want to try brown switches if you prefer something heavier than reds and lighter than blacks. You might also want to try blue. Blue is 5g heavier than brown, it also gives off a clicky feel on top of the normal tactile bump when actuating. Browns only have the tactile bump.
Red and black switches are the only two popular linear switches, most others have tactile points.
Offline hcry4
  • HHKB Hoarder
« Reply #55 on: Fri, 27 January 2012, 10:54:13 »
Quote from: mTwTT1;500660
The actuation is between them at 55.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #56 on: Fri, 27 January 2012, 10:55:22 »
http://geekhack.org/showwiki.php?title=Cherry+Corporation+Switch+Wiki
According to the wiki it is between the two. But the stem causes it to have a bigger "bump" (than browns).
Fight For Freedom. Stand with Hong Kongers
Offline tsangan
  • 1000/600
« Reply #57 on: Fri, 27 January 2012, 11:26:21 »
Clears are not fun to game with, ergo clears on the other hand I can see being good
Keyboardless
Offline mTwTT1
« Reply #58 on: Fri, 27 January 2012, 12:06:14 »
so i google translated every filco keyboard on pchome and wasnt able to find a tkl blue switch board, are there any at all?
http://ecshweb.pchome.com.tw/global/#!filco
Offline flyball
« Reply #59 on: Fri, 27 January 2012, 12:08:59 »
[SIGPIC][/SIGPIC]
Offline Glukos
« Reply #60 on: Fri, 27 January 2012, 12:13:41 »
Nope... You can try  armygroup.com.tw(about $55 shipping) or Qtan's store Qtan's store (about $22 shipping) =)
Offline Glukos
« Reply #61 on: Fri, 27 January 2012, 12:43:43 »
By the way, what's your mouse and the mouse pad? =)
Offline mTwTT1
« Reply #62 on: Fri, 27 January 2012, 12:59:17 »
mousepad = artisan hayate, my current mouse is a DA
Offline RiGS
« Reply #63 on: Fri, 27 January 2012, 13:06:03 »
Quote from: tsangan;500705
There are way too many complaints about sticky ergo clear switches.
Offline F u r u y á
« Reply #64 on: Fri, 27 January 2012, 13:15:26 »
indeed, ergo clears have what I call "upstroke hysteresis"
impossible to fast double tap in that ****! terrible for sc2
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
