Author Topic: Do PBT rgb kits exist?  (Read 5070 times)
Offline lightsout714
« on: Thu, 26 January 2012, 22:07:48 »
I don't like having multiple types of keycaps on a keyboard. Has anyone ever seen a pbt rgb kit? I am also looking for a red WASD. I think qtan said he could get that I will have to ask him.
« Reply #1 on: Fri, 27 January 2012, 01:39:43 »
Quote from: lightsout714;500226
Didn't that desko one have those?
http://geekhack.org/showthread.php?26130-Great-RBG-set-find!-lt-Not-for-sale-lol-gt
fossala
  •  Guest
« Reply #2 on: Fri, 27 January 2012, 01:51:07 »
Unicomp do them but that would only word for BS keyboards.
« Reply #3 on: Fri, 27 January 2012, 02:12:30 »
considering what the cherry ones are supposedly worth, I think it'd be much easier to get some cheap ones from unicomp and modify them for cherry MX usage.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Fri, 27 January 2012, 02:14:14 »
Buy normal PBT caps and use RIT dye.
fossala
  •  Guest
« Reply #5 on: Fri, 27 January 2012, 02:15:35 »
Quote from: WhiteFireDragon;500401
I RIT dyed my unicomp spacesaving keys. Was easy and worked well.
« Reply #6 on: Fri, 27 January 2012, 02:17:59 »
Not really a fan of the dye. I wonder how hard it would be to mod a BS cap to a cherry. Aren't the BS caps two peices?  Sounds like more trouble then its worth I may give it a look for the hell of it though.
Sent from my Transformer TF101 using Tapatalk
fossala
  •  Guest
« Reply #7 on: Fri, 27 January 2012, 02:21:14 »
Quote from: lightsout714;500405
Mine are on my Unicomp. Except the stabilized keys.
