Author Topic: Need help finding a mechanical keyboard!  (Read 3481 times)
Offline deltz
« on: Fri, 27 January 2012, 15:14:39 »
My previous keyboard was the Razer Blackwidow, spilt coke over it and it died!!
I want:
.Full size keyboard if possible
.UK Layout
.Not blue switches(I want something that needs less force needed to apply to keys because of wrist pain, I dont mind the clicky sound)
.Used mainly for typing not so much gaming
.Budget of £150
.Would love to get colored keys for the WASD buttons
Any help will be great, any UK websites where I can buy mechanical keyboards?
Offline rainb1ood
  • so pretty so plastic
« Reply #1 on: Fri, 27 January 2012, 15:22:46 »
Get the Filco Majestouch 2 104's Brown switch
Ninja key caps: http://www.keyboardco.com/keyboard_details.asp?PRODUCT=932
Regular key caps: http://www.keyboardco.com/keyboard_details.asp?PRODUCT=646
Offline rhizo
« Reply #2 on: Fri, 27 January 2012, 15:29:09 »
Quote from: deltz;500918
I want:
.UK Layout
.Budget of £150
If you order from wasdkeyboards.com they will ship to uk, you can choose which switches, and you can customize your keycaps, great quality, not heard much if anything bad about them atall.. :)
Offline deltz
« Reply #3 on: Fri, 27 January 2012, 15:41:25 »
Thanks for the suggestions, the WASD site has got me drooling!!
Is there any other keyboards apart from the FILCO that you might recommend?
Offline rhizo
« Reply #4 on: Fri, 27 January 2012, 15:47:15 »
Quote from: deltz;500936
Filco, coolermaster storm, wasd, and a few others people will probably quote you, all come out of the same  factory so take your pick!
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #5 on: Fri, 27 January 2012, 15:48:05 »
Not really for UK layout.
Just remembered a big reason why I hate my Uni's keyboards... All UK layout. Why is quotation marks shift+2 and not above the apostrophe. It makes no sense. Why is backslash in the weirdest place? WHY?
Back on topic.
Filco's a good board = ).
WASD is customizable = D
Fight For Freedom. Stand with Hong Kongers
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #6 on: Fri, 27 January 2012, 15:48:39 »
It you are having wrist troubles, you may want to consider looking at ergonomic boards such as the Kinesis.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline deltz
« Reply #7 on: Fri, 27 January 2012, 17:01:43 »
Thanks for all the inputs, I think filco might be the one but not so sure on the Kinesis.
Will the custom keys from wasdkeyboards.com work on the filco keyboard.
How much easier is the brown switches to press than blue ones, is red switches another option?
Offline rhizo
« Reply #8 on: Fri, 27 January 2012, 17:56:14 »
Quote from: deltz;500999
brown switches have the same weight of spring as the reds, 45g compared to the 55 of the blues, so id say the browns are your best bet :)
Offline Tony
« Reply #9 on: Sat, 28 January 2012, 00:48:58 »
Browns are 10g lighter and designed specifically for typing, so Filco brown or WASD brown are the best bet for you.
Offline Autolyze
« Reply #10 on: Sat, 28 January 2012, 09:22:55 »
Quote from: rhizo;501048
Blues use that spring as well. The difference in force between reds, browns, and blues just comes from the tactile point near actuation. Reds are fine for typing if you don't care about feeling the exact point when the key is registered, and are noticeably lighter than browns to type on.
Offline rhizo
« Reply #11 on: Sat, 28 January 2012, 09:24:25 »
Quote from: Autolyze;501471
you knew what i meant ;)
Offline stingrae
« Reply #12 on: Sat, 28 January 2012, 18:15:44 »
Quote from: hazeluff;500945
Back on topic.
I completely agree, it really doesn't make any logical sense. Mind you if you aren't a science person the positioning of += is of little value and why on earth do keyboards lack degree symbols meh guess someone hated geometry and took it out on the layout of the keyboard ^^.
On topic for UK layout theres also Das but I reckon you really can't go wrong with a filco or wasd..
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
