Author Topic: How to use key collars(topre)?  (Read 1516 times)
Offline HaiiYaa
« on: Fri, 27 January 2012, 15:37:25 »
I have looked everywhere in the forum about key collars but nothing shows up when I search for it
This is the keyboard I have
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=866
Appearently its without dip-switches but I recieved 4 key collars to disable keys. I just have no idea how to use them
Offline tsangan
  • 1000/600
« Reply #1 on: Fri, 27 January 2012, 15:40:22 »
If you want to use it for example the left win key, take off the alt key to the right of it and slide the key stopper in from the right side
Cherry you have to slide the key stopper from above the key you want to use it for
Reference:
http://geekhack.org/showthread.php?16293-Realforce-103UB-vs-103U-UW&p=315783&viewfull=1#post315783
after it didn't work for my Cherry keyboard that's how I found out you have to go from the key above and not sideways
Keyboardless
Offline RiGS
Offline HaiiYaa
« Reply #3 on: Fri, 27 January 2012, 15:56:26 »
thank you
