Author Topic: I'm new to the club and pulled the trigger a while ago  (Read 3948 times)
Offline Llama16
« on: Sat, 28 January 2012, 07:22:17 »
Hey all,
Just wanted to say that I'm new here and a new owner of my own first mechanical keyboard.
I recently bought myself a Filco Majestouch 2. It was a hard decision because it is ALOT of money. But I used to have this great ancient (yellowturned) IBM mechanical keyboard and I was certain that I wanted another longlasting keyboard that sounded and typed great.
I've been using it for a week now and I must say it types really great. The thing is, whenever you (at least 'I') spend so much money on something, I tend to notice the smallest faults, just as much as I would notice faults when I make something, they're there and you'll never ever forget them while other might not even notice it.
Well, I've got key (that i use, insert as well) 'Y' that pings (a very high pitched noise that stays for over second sometimes and is a different pitch then some of the others). And one that rings, the tab.
I bit of a bummer, but hey nothing I can do about it I think, hopefully I'll be able to let it go :D
But so far so good, I even caught myself looking at other cherries to try out, but I seriously had to stop myself.
Dries
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1 on: Sat, 28 January 2012, 08:37:00 »
Well welcome to GeekHack ^_^
Hope you can get used to it. I would say its a your imagination.
I have the exact same keyboard and don't have any problems.
Fight For Freedom. Stand with Hong Kongers
Offline Barn
« Reply #2 on: Sat, 28 January 2012, 08:50:12 »
Enjoy your new board!
Every key pings for me and I don't care the slightest, you'll get used to it.
Offline Llama16
« Reply #3 on: Sat, 28 January 2012, 08:54:01 »
Quote from: hazeluff;501456
I'll probably get used to it but it's certainly not my imagination. Did a blind test (someone else randomly pressed keys) and I took out those ones every times, no matter how he pressed them. Also have video prove, but it's not as loud as I hear it as the mic on the camera has problems with high pitched noise.
Maybe it even goes away after a while and is just breaking in.
Offline Gin
« Reply #4 on: Mon, 30 January 2012, 10:52:29 »
Have you thought about RMA?
Offline mmmty
  • bang! bang!
« Reply #5 on: Mon, 30 January 2012, 10:57:19 »
for the record, my new yellow Filco tenkeyless w/ browns is pingless.
Keyboardless
Offline Llama16
« Reply #6 on: Mon, 30 January 2012, 14:39:51 »
Hey guys,
Yeah it's gotten better. The tab I don't notice anymore and the Y has actually gone away after a week or so, it now rings but that's less annoying then that high pitched noise from before and I hardly hear it (allthough still distinguishable).
I've got some blan keycaps coming in as well :D
Offline TacticalCoder
« Reply #7 on: Mon, 30 January 2012, 17:07:25 »
Quote from: Llama16;503434
The 'click' and it's "audio feedback", I can't live without.  But the resonating 'piiiiiiiing', I used to live with it for years then I discovered GH and found the "dental floss" mod.  You basically remove all the keys and put a little something inside the springs, preventing them from resonating.
I did it on all keys besides the numpad of my daily driver and the difference is huge.
So do a search here for the "floss mod", you may like it!
Offline keyboardlover
« Reply #8 on: Mon, 30 January 2012, 19:06:00 »
Welcome to GH! We tend to be a trigger-happy bunch.
Offline naranja
« Reply #9 on: Mon, 30 January 2012, 19:27:53 »
Can I ask where you bought your board?
