Author Topic: Filco Number Pad stabilizers  (Read 6943 times)
Offline daerid
    • Rossipedia
« on: Sun, 29 January 2012, 18:26:29 »
I picked up a Filco number pad to complement my MJ2, and was totally disappointed to find out that  the enter and + keys use Cherry style stabilizers. Yuck.
Does anybody know if there is any way to convert the cherry stabilizers over to Costar-style?
Offline quake4mhg
« Reply #1 on: Sun, 29 January 2012, 22:45:13 »
Oh no, I just brought it, coming into my mail. What is the bad thing using the stabilizer?
Offline lorem3k
    • http://twitter.com/#!/lorem3k
« Reply #2 on: Sun, 29 January 2012, 22:48:54 »
Are people just exaggerating, or are Cherry stabilizers really that terrible?
Leopold FC200RT/AWN | Logitech G400 | Sennheiser HD25-1 II | Pounds in the fridge, hundred stacks in the armoire
Offline CaiSter21
« Reply #3 on: Sun, 29 January 2012, 22:59:24 »
Quote from: lorem3k;502894
they arent that terrible, ppl are just being fanboyish.
to each his own opinion.
Ducky Shine DK 9008S Red LED |Rosewill RK-9000BR
Offline squarebox
  • In Omnia Paratus
« Reply #4 on: Sun, 29 January 2012, 23:23:41 »
Costar stabilizer tend to retain the switch's feel but it's troublesome when swapping keycaps
Cherry Stabilizer tend to make the switch feel mushy/more resistance(due to the side-wall of cherry stabilizer) but it's easy to swap keycaps
I personally I prefer Costar stabilizer.
People normally dont change keycaps that often that it becomes a PITA.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline lorem3k
« Reply #5 on: Sun, 29 January 2012, 23:33:45 »
Thanks for the info squarebox. Perhaps longer keys with Cherry stabilizers could be modded with a lighter spring in the switch to remove the mush/resistance to have the best of both worlds, might have to give it a try if I decide to get a Leopold
Offline flyball
« Reply #6 on: Sun, 29 January 2012, 23:38:11 »
Quote from: lorem3k;502928
it doesnt work that way. that would just lighten the entire travel of the switch.
[SIGPIC][/SIGPIC]
Offline squarebox
  • In Omnia Paratus
« Reply #7 on: Sun, 29 January 2012, 23:54:47 »
Like flyball said, it doesn't work that way.
The mushy/resistance feel is caused by stabilizer. The side walls is to blame. Lubing it would help.
Excuse the watermark. There were days that people who stolen my pics and claiming it as theirs.
« Last Edit: Mon, 30 January 2012, 00:00:45 by squarebox »
Offline limmy
« Reply #8 on: Mon, 30 January 2012, 01:59:26 »
I personally prefer Cherry style stabilizers.
The mushiness is more prominent when new, but seems to be reduced over time. Beside the convenience of replacing caps, I feel the additional structure gives feeling of sturdiness.
Offline RiGS
« Reply #9 on: Mon, 30 January 2012, 02:13:05 »
You can always grind down those walls with a dremmel.
Offline kaiserreich
  • HHKB Elite
« Reply #10 on: Mon, 30 January 2012, 02:15:47 »
Harder springs would probably enhance the keyfeel with the stabilizers rather than the other way around, based on what I have tried out with Black and Brown switches.
« Last Edit: Mon, 30 January 2012, 02:21:39 by kaiserreich »
Offline daerid
    • Rossipedia
« Reply #11 on: Mon, 30 January 2012, 11:50:19 »
Quote from: CaiSter21;502898
For me, it has nothing to do with fanboyism. It affects how I actually strike the keys, and the inconsistencies between the normal keys and the keys with Cherry stabilizers actually causes fatigue in my hands/fingers. To the point of pain sometimes.
Back to the original question: Can I change them?
