Author Topic: Teensy Keyboard Firmware Discussion  (Read 9790 times)
Offline hazeluff
  • 光復香港
    • Hazeluff
« on: Sun, 29 January 2012, 20:15:59 »
Just to remove the amount of posts in the Phantom GB about firmware and things about it. This thread has been made.
Feel free to discuss, ask questions, help out.
At the moment I think it'll be focusing on PHANTOM/DOX keyboards, but it doesn't limit it just to those two.
I'll be uploading my firmware and helping out a lot here.
If you've seen my signature, I'm willing to help draw up layouts for if you want like Custom WASD keycaps.
Here's my layout for now:
[ Attachment Invalid Or Does Not Exist ] 38978[/ATTACH]
« Last Edit: Sun, 29 January 2012, 20:26:03 by hazeluff »
Fight For Freedom. Stand with Hong Kongers
Offline tsangan
  • 1000/600
« Reply #1 on: Sun, 29 January 2012, 20:19:36 »
We should have the OP containing all the different layout everyone is doing + the firmware they are using, so people can swap around and try them out, like a little teensy library :)
Keyboardless
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #2 on: Sun, 29 January 2012, 20:22:06 »
Quote from: tsangan;502745
PLACE HOLDER FOR EXACTLY THIS
Offline TheProfosist
  • Custom Layouts Only!
« Reply #3 on: Sun, 29 January 2012, 20:23:53 »
thread stuck
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #4 on: Sun, 29 January 2012, 21:08:12 »
subscribed!
Offline litster
« Reply #5 on: Sun, 29 January 2012, 21:47:15 »
Hum, I was actually thinking to create a dedicated thread for just Phantom soldering discussion and firmware discussion for a one stop shop for am Phantom technical needs.  This is actually not the thread I was hoping to create.
Phantom soldering instruction wiki: http://deskthority.net/wiki/Phantom_Instruction
Phantom Firmware from PrinsValium:
Phantom Plates:
Working firmware for PHANSI layout.  This version is currently running on Phantom prototype:  PHANSI.HEX
EDIT1: added PHANSI.HEX for PHANSI layout.
« Last Edit: Sun, 29 January 2012, 21:51:32 by litster »
« Reply #6 on: Sun, 29 January 2012, 22:23:51 »
Quote from: litster;502824
Phantom Plates:
best my guest and make the thread pleanty of space in my subforum.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #7 on: Mon, 30 January 2012, 00:00:54 »
can someone link how to build a working teensy compile toolchain in one of the initial posts? is there a teensy howto somewhere?
Offline litster
« Reply #8 on: Mon, 30 January 2012, 03:07:01 »
Hi guys.  I started a Phantom solder instruction on deskthority.net.  But there isn't really a discussion feature there.  There is, but it is just another wiki page it seems like.  I thought about starting a new page on the mod section here on GH, but I don't think people can change the original post of a mod page.  I think I will start a wiki page here with a pointer to the deskthority.net phantom wiki page, and links to other attachments.  I want people be able to edit and update the original instruction *and* be able to have a continuous discussion in the GH wiki section.
EDIT:
Looks like the mod section is the same as wiki.  Maybe I will stick it there instead.
« Last Edit: Mon, 30 January 2012, 03:10:02 by litster »
Offline bpiphany
« Reply #9 on: Mon, 30 January 2012, 03:52:49 »
Quote from: mkawa;502943
http://pjrc.com/teensy/index.html
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #10 on: Mon, 30 January 2012, 08:18:17 »
Litster's thread is much more detailed, specially for Phantom. But no worries, we welcome everyone here @_@.
Offline litster
« Reply #11 on: Mon, 30 January 2012, 11:08:06 »
This thread is cool too.  There are certainly a lot in common between Dox and Phantom, and most likely there is a lot to share between the two versions at the source code level.  My goal is to have one single thread to cover all Phantom building needs and discussion.  This thread can serve as the bridge to share firmware knowledge and design between Dox and Phantom.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #12 on: Mon, 30 January 2012, 11:36:49 »
Quote from: litster;503220
Exactly = D
I'm quite excited for the Phantom. I want mine NAO.
Offline riffautae
« Reply #13 on: Mon, 30 January 2012, 21:24:46 »
I got my tool chain working again. There was a bug in binutils. Anyway its not working quite yet but its pretty close... something silly is blocking it. The code for the tmk derivative is at my github if anyone wants to help me debug it. This has media keys, multiple layers etc.
« Reply #14 on: Tue, 31 January 2012, 00:34:42 »
Well im trying to find hazu's dox firmware so you can just repurpose the code but i cant seem to find it anywhere
Offline Dox
« Reply #15 on: Tue, 31 January 2012, 17:28:33 »
Quote from: TheProfosist;503965
Here: https://github.com/doxkb/tmk_keyboard
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
« Reply #16 on: Tue, 31 January 2012, 19:47:48 »
Quote from: Dox;504679
Thanks lots!
Offline riffautae
« Reply #17 on: Wed, 01 February 2012, 09:16:49 »
Nice, looks like his is based on tmk like mine is, so I have already done 99% of the work needed to get phantom working with that firmware.
« Reply #18 on: Wed, 01 February 2012, 21:03:53 »
Quote from: riffautae;505206
Nice sounds great how far are you along with that and are you currently able to test it?
Offline riffautae
« Reply #19 on: Wed, 01 February 2012, 23:22:40 »
Quote from: TheProfosist;505844
TBH I think I have all the code done that would make it work, I just messed something tiny up and need to find it. Yes I have a teensy, there is also simulavr for more indepth debugging with gdb.
« Reply #20 on: Thu, 02 February 2012, 00:52:31 »
Quote from: riffautae;506009
great to hear do you think well have a working firmware when the Phantom ships?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #21 on: Thu, 02 February 2012, 10:08:57 »
I'm dling simulavr as I write this. See if I can be debugging my layout before I even get my Phantom. And maybe write up some templates = p
Edit: Simulavr is a pain in the ass to do on Cygwin. Getting WinAVR now.
Edit2: Changed my mind again getting the AVR Plugin for Eclipse.
« Last Edit: Thu, 02 February 2012, 10:29:31 by hazeluff »
Offline riffautae
« Reply #22 on: Thu, 02 February 2012, 10:27:43 »
Nice, with the tmk firmware I made layouts and such a bit easier. you can just put them in phantom/layouts and then include them in the layer array in whatever order. This means I can keep popular layouts in the repo and people just move around the includes.
As far as being done, I hope so. Since I got the toolchain working again I should be able to step through with gdb and see where it is hanging.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #23 on: Thu, 02 February 2012, 13:24:25 »
I think i just got WinAVR stuff installed correctly to use with eclipse...now lets see if I can get some simulation going...
Offline riffautae
« Reply #24 on: Thu, 02 February 2012, 14:05:49 »
Quote from: hazeluff;506492
Sweet, I hang out in the IRC if you need to chat about any of it.
Offline mkawa
« Reply #25 on: Mon, 06 February 2012, 20:00:54 »
can whoever put the code on github repost the repo link?
Offline riffautae
« Reply #26 on: Mon, 06 February 2012, 20:04:46 »
Offline Hzza
« Reply #27 on: Tue, 07 February 2012, 09:29:16 »
Is anyone working on ISO Phantom firmware? If not, how difficult would it be for someone with absolutely no experience to repurpose the ANSI firmware?
Also, I've been working on some layout ideas but I don't know the limitations of the Teensy; how many different FN layers are possible and are mouse movement keys possible? I've read through some of the links above but they're quite a bit above my understanding tbh, so would like a simple answer for my simple brain.
Cheers,
Tom
Offline litster
« Reply #28 on: Tue, 07 February 2012, 09:35:56 »
Phantom firmware is already working.  To create an ISO firmware, it is just a matter or remapping a few keys in the array and recompile.  That is it.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #29 on: Tue, 07 February 2012, 23:02:04 »
Quote from: litster;508158
Unless you are me and like adding extra functions like Windows key disable and using numlock for swapping in and out of the 7bit numpad thing = D.
Offline litster
« Reply #30 on: Tue, 07 February 2012, 23:46:35 »
Disabling Windows keys is the same as assigning nothing to the row, column pair for the Windows keys, or changing them to whatever you want.  No big deal.  Current firmware doesn't support layers.  For that you do need to modify the firmware.  But that is outside of the scope of Hzza's question.
« Reply #31 on: Wed, 08 February 2012, 00:27:36 »
Quote from: hazeluff;508923
Same here im going to custom firmware as well. I hope that The DOXs gets converted over so that we have all those additional features that are crucial to my layout
Offline mkawa
« Reply #32 on: Wed, 08 February 2012, 10:36:20 »
i should be able to do all of this stuff but probably not until later next week, as i have a huge stack of grading to do and more incoming...
except for the mousekeys stuff; i don't know enough about the usb hid device protocol to know whether that's possible...
« Last Edit: Wed, 08 February 2012, 10:55:02 by mkawa »
« Reply #33 on: Wed, 08 February 2012, 15:23:13 »
Quote from: mkawa;509242
It was possible with Hazu's firmware on the DOX but if that cannot now be done its not the end of the world, it would just be something that I would benefit from as I am more accurate with the mouse when I dont have to click with it.
Offline riffautae
« Reply #34 on: Wed, 08 February 2012, 21:26:31 »
):< I ported the new code to avr studio 5, but it turns out atmel's simulator wont do the teensy processor!
If anyone wants that version I can upload it, it compiles but I don't know anything else.
Offline mkawa
« Reply #35 on: Sat, 11 February 2012, 09:19:20 »
ugh, undergrads! i'll let you know when i'm ready to start hacking riff.
Offline mkawa
« Reply #36 on: Sun, 19 February 2012, 19:57:42 »
ping
i cannot for the life of me get simulavr running on teensy binaries. atmega32 doesn't seem to be a supported micro for the simulavr in the ubuntu package.
« Reply #37 on: Mon, 20 February 2012, 08:58:03 »
well i changed up my layout a bit http://tinyurl.com/7u6oczr I really hope someone can write up some code to get it o run.
