Author Topic: how's this key cap puller?  (Read 2762 times)
Offline Deadly55
« on: Mon, 30 January 2012, 02:23:05 »
[ Attachment Invalid Or Does Not Exist ] 38988[/ATTACH]
My first attempt..
Offline Glukos
« Reply #1 on: Mon, 30 January 2012, 02:54:47 »
Looks deadly!
Offline squarebox
  • In Omnia Paratus
« Reply #2 on: Mon, 30 January 2012, 03:02:15 »
At first I thought you were hanging this infront of your Deathadder:
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline shogrran
« Reply #3 on: Mon, 30 January 2012, 03:41:50 »
I thought it was a spider as well.
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
Offline Zifle
  • Nyaaa
« Reply #4 on: Mon, 30 January 2012, 05:45:51 »
I saw it as some advanced spider puller as well. Would it work as a keycap puller?
I like cats.
Offline Sephiroth
« Reply #5 on: Mon, 30 January 2012, 05:47:59 »
Deathadder....
Offline dj christian
« Reply #6 on: Tue, 31 January 2012, 11:26:46 »
Man that is cool! Can you make a guide how to do that?
Offline Deadly55
« Reply #7 on: Tue, 31 January 2012, 13:31:40 »
it's pretty simple. Take two paper clips straighten them out. take one of them and bend it up so you got a flat U shape ( I had a key that i used to make sure the size was fine), and then you bend the ends to make a bit of a hook, and repeat for the ot her side.. and then you just  twist the ends onto the  third paperclip, bend the ends so it doesn't come off and voila spider. It's actually pretty easy as all you need is a few paperclips and pliers.
Offline captain
« Reply #8 on: Sun, 04 March 2012, 02:26:20 »
Quote from: squarebox;503025
I think that is a female orbweaver; the males look totally different, and used to scare the hell out of me.
...and I thought the same thing from his thumbnail!  hehe
« Last Edit: Sun, 04 March 2012, 02:30:44 by captain »
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline mickd
« Reply #9 on: Sun, 04 March 2012, 07:20:42 »
Haha I'm kind of disappointed that it wasn't a spider. It sure looks like one from the thumbnail.
Offline CeeSA
« Reply #10 on: Mon, 05 March 2012, 09:14:50 »
we have the same base ;)
