Author Topic: Only change feather in a cherry mx switch?  (Read 2143 times)
Offline hei
« on: Mon, 30 January 2012, 14:27:05 »
Hi
I am wondering if you can open a cherry mx brown switch and change the feather in it to a feather from a black switch ? Is there anything bad with doing this ?
fossala
  •  Guest
« Reply #1 on: Mon, 30 January 2012, 14:28:45 »
Feather? That doesn't make sense. Do you mean spring or stem?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Mon, 30 January 2012, 15:16:15 »
I hope you don't have feathers in your switches. Don't pluck chickens over your keyboards.
You can swap springs and/or stems in switches. A lot of us here do to put switch on board that does not come with a particular type, or to make hybrids. Depends on the board on how involved it is, but if you do it correctly it won't cause problems.
Offline Gawkbasher
« Reply #3 on: Mon, 30 January 2012, 15:24:44 »
I dunno about you Cherry owners but I just changed the feathers in my Topre switches.
[ Attachment Invalid Or Does Not Exist ] 39048[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 39049[/ATTACH]
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Mon, 30 January 2012, 15:26:25 »
Seeing a feather in your Topre, I fear finding out what hair that is on your F2.
Filco w/ Imsto thick PBT
Offline Gawkbasher
« Reply #5 on: Mon, 30 January 2012, 15:27:34 »
Quote from: alaricljs;503472
Hahaha...that's actually not a hair, believe it or not -- I know it looks bad...
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #6 on: Mon, 30 January 2012, 15:29:38 »
Quote from: Gawkbasher;503469
(Attachment Link) 39048[/ATTACH] (Attachment Link) 39049[/ATTACH]
Lol.Why do you have feathers just sitting around so you could do that...
I think the guy either means springs/stems.
Fight For Freedom. Stand with Hong Kongers
Offline Gawkbasher
« Reply #7 on: Mon, 30 January 2012, 15:30:46 »
My down pillows shed feathers everywhere. :(
And I knew what he meant...just having some fun with it.
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline Ascaii
« Reply #8 on: Mon, 30 January 2012, 15:31:31 »
Ill bet OP is german...in german a spring is called "Feder" which also means feather...^^
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #9 on: Mon, 30 January 2012, 15:37:29 »
Quote from: Gawkbasher;503477
I know. And I laughed again looking at the picture.
OP to answer your question, Yes you can. But you can't open a switch that is plate mounted without desoldering the switch from the board.
Offline boli
« Reply #11 on: Mon, 30 January 2012, 15:40:43 »
First of all: :becky:
Dunno if hei is from Germany, as feather and spring are the same word in german.
Switching springs is easy enough, unless the switches are plate mounted.
[video=youtube;GivKt63dLvA]http://www.youtube.com/watch?v=GivKt63dLvA[/video]
Video was shown to me by sordna and made changing the Cherry MX brown keys on the thumb cluster of my Kinesis Advantage a lot easier than resoldering. :)
As for the effect of replacing the spring in the brown switch with one from a black, the Wiki might be of help. ;)
Update: I guess I took a while posting, sorry for the redundancy. ;)
Keyboard: Kinesis Ergo Advantage (two LF editions with red Cherry switches, one regular with brown switches)
Keyboard layout: basically Colemak, with some remapping to end up with my custom Kinesis Advantage layout
Typing test profiles: typeracer.com / hi-games.net / keybr.com
Offline hei
« Reply #12 on: Tue, 31 January 2012, 14:58:57 »
Thx for the answers, exactly what i was looking for =)
Btw feather and spring has the same word in Swedish too so I didn't think too much about what word i used in English xD
