Author Topic: LITTLE PROBLEM W/COLEMAK  (Read 3573 times)
Offline dewcorps
« on: Mon, 30 January 2012, 18:37:53 »
MY KEYBOARD SEEMS TO NOT BE ABLE TO GET OUT OF CAPS LOCK. ALSO COLEMAK DOES NOT SEEM TO HAVE CAPS LOCK. WAT DO?
Offline erw
« Reply #1 on: Mon, 30 January 2012, 18:43:47 »
Cruise control for cool :panda:
What's your OS and how did you get Colemak on it?
A one-off fix might be switching to qwerty, toggling caps lock and going back. Or rebooting.
Then if you don't want it do happen again, find out how it is toggled. Maybe it's a feature, for example, I toggle caps lock by pressing both shifts at the same time. But I had to enable that myself (Linux).
Kinesis Advantage LF (MX Red), Kinesis Advantage (MX Brown), Ergodox (MX Red), Colemak
Offline dewcorps
« Reply #2 on: Mon, 30 January 2012, 18:57:46 »
using xubunfu, rebooted into qwerfy, made sure caps was off, put info colemak, worked.
damn colemak is awkard, buf I like!
fook forever to fype.
Offline Tony
« Reply #3 on: Mon, 30 January 2012, 19:57:46 »
1. Switched to Qwerty, turn off Capslock, then turn back to Colemak.
2. For convenience, I use this Autohotkey script to turn Ctrl-Capslock to Capslock:
^Backspace::Capslock
(thanks to Pavel - Paftaka90 of Colemak forum)
« Last Edit: Tue, 31 January 2012, 23:35:11 by Tony »
« Reply #4 on: Mon, 30 January 2012, 20:36:54 »
Quote from: erw;503654
I'm interested in this: how? I know how to remap keys by making a custom keyboard layout (pretty easy, actually), but "harder" stuff like that needs another program, right?
Offline erw
« Reply #5 on: Tue, 31 January 2012, 09:01:00 »
Quote from: dorkvader;503761
In newer Ubuntus (Ubunti?), you can enable it in the keyboard settings. It's probably part of X.
[ Attachment Invalid Or Does Not Exist ] 39100[/ATTACH]
