Author Topic: Lists of Mechanical Keyboard features. Am I missing anything?  (Read 1775 times)
Offline ShakeR
  • * Commercial Vendor
    • http://mechanicalkeyboards.com
« on: Tue, 31 January 2012, 12:23:09 »
Here's what I've got so far, anything you can add to the list(s) is very much appreciated!
Layouts:
US ANSI 87
US ANSI 104
US ANSI 104+4
Key Plastics:
ABS
PBT
Switches:
Black Cherry
Brown Cherry
Blue Cherry
Red Cherry
Clear Cherry
Black Alps
Green Alps
White Alps (anyone know actuation force for white alps?)
Buckling Spring
Topre Key
Print Type:
Pad Printed
Laser Etched
Dye Set
Injection Molded
MechanicalKeyboards.com - What do you type on?
Offline bbbbqq
« Reply #1 on: Tue, 31 January 2012, 12:30:33 »
ISO layouts
Japanese layouts
Painted keys
Alpa of way more colors
See ripsters wiki
Offline Roguemaster8
« Reply #2 on: Tue, 31 January 2012, 12:31:05 »
Isn't the actuation force for white alps between 60g and 70g? I read it varied if they were complicated or not.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #3 on: Tue, 31 January 2012, 12:32:00 »
Layouts:
Tons of variations:
ISO and 7Bit layouts
Plastics:
POM
Resin (DYI keycaps).
Switches:
Green Cherry
Dark Blue Cherry,
Grey Cherry.
Printing:
Lazer Engraved
Also, INB4 Ripster.
Fight For Freedom. Stand with Hong Kongers
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Tue, 31 January 2012, 12:36:09 »
105 key, 109 key,
POM keycaps
think you mean dye sub where you have dye set
double shot would be more recognizable than injection molded
blank keycaps too
also front printed keycaps
presence of peripherals like USB hubs, trackpoints, trackpads, smartcard readers, mag-stripe readers,
matrix layout, stagger layout
backlighting, where the standard signal LEDs are (in key or near the numpad area)
Filco w/ Imsto thick PBT
Offline trax
« Reply #5 on: Tue, 31 January 2012, 12:37:51 »
Depends if you want a list of currently used switches or also older switches which are out of production.
Switches tried so far
Cherry MX Red Blue Black Clear
ALPS White Black (fake)Blue
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline ShakeR
« Reply #6 on: Tue, 31 January 2012, 13:23:13 »
Wow, you guys are amazing.  I had a feeling I was missing quite a bit...
Quote from: trax;504335
Looking for switches currently in production. Thanks!
Offline jkercado
  • Green XM clickclacker
« Reply #7 on: Tue, 31 January 2012, 15:44:26 »
Cherry ML switches!
Ducky 1087XM Green | Unicomp Ultra Classic Black | IBM M4 | 1989 IBM Model M | Genius i200 | Cherry G84-4100 | Microsoft Arc Keyboard
Offline enoy21
« Reply #8 on: Tue, 31 January 2012, 15:46:36 »
Are you trying to reinvent the wheel that Ripster has already built ?
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline ShakeR
« Reply #9 on: Tue, 31 January 2012, 16:16:11 »
Quote from: enoy21;504604
I tried delving through his wiki, most of the information that I can find is either over my head or not what I'm looking for.
I've gotten more out of the posts above than I did looking through it; HOWEVER, I know this is likely my fault as I'm not looking in the right place in his documentation.
Offline ShakeR
« Reply #10 on: Tue, 31 January 2012, 16:48:36 »
Is there a difference between Laser Etched and Laser Engraved caps?
Offline Armando Penblade
    • http://thegeekery.org
« Reply #11 on: Tue, 31 January 2012, 17:41:23 »
Quote from: ShakeR;504652
Well, there are keycaps (like some available from WASDKeyboards) that have the letters "carved out" of the plastic via laser. The area is left empty.
Then there are keycaps where a thinner letter "shape" is lasered into the key, and then the resulting "bed" is filled with ink. AFAIK, this is how the keys are printed on the SteelSeries 6Gv2. It tends to result in both a more evident feeling where the "printing" is than pad-printed keys and results in legend wear that has the letters discoloring rather than rubbing off. You can eventually wear away all the ink in the hollowed out spaces, but it might take a good long while for a decently made key.
Filco Majestouch 104-US, Metallic Blue, with Chery MX Blues  //  Microsoft Comfort Curve 2000, 104-US + Media Keys & Browser Controls  //  iRocks RF-6570 Cordless 104-US, 2.4GHz Wireless, White  //  SteelSeries 6Gv2 104-US, Black, with Cherry MX Blacks
Offline alaricljs
« Reply #12 on: Tue, 31 January 2012, 19:20:24 »
To add to what Armando said, there is a method whereby the color of the keycap is changed with a laser which is WASD's laser etching process.  The other process WASD uses is called laser engraved, there is no contrast just the letter carved out of the key surface.
Offline enoy21
« Reply #13 on: Wed, 01 February 2012, 07:15:03 »
Quote from: ShakeR;504633
I will admit that the organization could be managed better to allow a more fluid flow of information.
WASD 104 work
WASD 104 home
